Old 05-31-2011, 06:36 PM   #1
Control Freak's Avatar
Cool RB Killer 10
Does anybody know the specs ( HP & RPM) on the RB Killer 10? If you own this engine I would like to hear your pros & cons please. Thank you!
Control Freak is offline   Reply With Quote
Old 05-31-2011, 08:38 PM   #2
This is an off-road engine, but ill still give u the specs anyway
Contents: 3.49 cc
Bore: 16.20mm
Stroke: 17.00mm
Porting intake: 5+2 by pass
Porting exhaust: 1
Crankshaft: 14mm
Carburetor: Composite 8mm with removable Venturi
Glowplug: Turbo #01051-6
Weight: 345 Gr.
Use: Buggy
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
SEO by vBSEO 3.5.0
