Kyosho v-one rrr
#9588
KYOSHO EVO .WC Team Edition RTR
kl
#9589
car for sale
hey all i have a v-1rrr for sale
it can come with M8 and spectrum and engine or as a roller.
dont know what the going price is since i have been out of it for a while but make me a reasonable offer. car is mostly stock and well kept.
#9590
Hi!i want to use 0 offset wheels in my wce rrr.what can i do?i dont want to replace the stock cvd's
#9591
Location: Cebu City, Philippines and Ocala, Florida, USA
You can use the Kawahara aluminum wide wheel hex hubs... These aluminum hex hubs are thicker than the standard hex hubs thus allowing you to use 0mm offset tires in the rear... Hope this helps...
#9592
yes,but i have read somewhere that these are 1mm offset..
#9593
I got mine from Ashford Hobby they have them in stock
http://www.ashfordhobby.com
This will get straight to the part on the site http://ashfordhobby.com/detail.aspx?ID=5649
#9594
#9595
Rear tyre wear
Regardless if I run 40's all round or 42's all round, the rear tyres are wearing down a lot more than the fronts. I can use the fronts for 2 heats and gets about 1mm of wear.
I true the tyres down to 60mm rear, 58mm front with 1-2mm front droop and 5-6mm rear droop.
The care setup is stock otherwise, with 2 deg camber on the front and 3 on the back.
Any reason why Im getting heaps more tyre wear on the rears? Can I get rid of this with another setup?
#9599
Cheers
#9600
I ran the 2D clutch with the 4 weights (only comes w/2) today and the car ran really well. Coming out of the turns on-throttle (technical track with ~ 12 turns, 250ft straight, medium traction), the car was very fast.
