Kyosho v-one rrr
#8237
Originally Posted by jag
You may have too much steering.
Just my opinion.
#8238
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally Posted by Racing4Evo
I think your front diff is too loose. Try running the solid or 100k.
Tires will solve the majority of handling problems. Have you tried 42F?
#8239
Originally Posted by kewdawg
-Reduce your rear diff oil to 10,000 wt., your shock oil to 60wt./40wt., rear shock position to 3rd from bottom, rear toe to 3 degrees toe-in, med.(black) rear swaybar (to control the roll better) 5.0 mm / 5.0 mm ride height. If, you haven't already, remove the spacer under the rear camber link and use the outer hole on the bulkhead mount. The car should be easy to drive but still very nimble.
#8240
Why aren't you using a front sway bar? You may have too much steering. If the rear can't hang, take some away from the front. I would also try 3 deg of toe-in in the rear.
Just my opinion.
Just my opinion.
#8241
Come over to 3hobby.net, look in the news items below the Forums Center, there is an offer to buy one RRR WC kit and you get a full RRR Evo kit with it. Get together with a friend and get it if you don't want two cars.
#8242
Originally Posted by doki_doki
hmm...that got me thinking will try all your suggestion tomorrow and see how it goes. by the way, i'll be moving to jacksonville, florida soon. is there a racetrack there? thanks
It sounds to me the reason the locals dont use the bars..could be because the track is bumpy there using lots of droop and need a lazy car just an observation..
#8243
not sure about jacksonville......but we do have a state series check it out www.forgass.com bunch of guys on this forum race in florida all over including me...
#8245
#8246
#8247
Hello All,
I have been searching trying to find a chart for gearing on the RRR that shows what gears go with what and the ratios that they make when combined.
Can anyone possibly point me to a chart or if possible PM or email it to me?
All or any help is greatly appreciated
Thanks,
Brett
Thanks,
Brett
#8248
Have a look on this file
http://www.kyosho.co.jp/web/download...rr_basic_e.pdf
I didn't understand everything that you said, but I hope this can help you
#8249
Thats it.
The gear ratios is what I needed, Thanks Mate
Cheers
Cheers
#8250
[QUOTE=kewdawg]
Good until this weekend landed the flu & been layedup in bed sucks wanted to go practice this weekend but you how it is. How ya been Kew getting ready for the winter season. Kew when did you start getting all decked out with the avatars
Originally Posted by 710baby
What-up, George!? How ya' been, Hommie?
