Kyosho v-one rrr
#8224
Originally Posted by maskedrider
hello everyone butties
#8225
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally Posted by kewdawg
Also, you could try a softer rear spring, lighter shock oil, more negative camber.
#8226
[QUOTE=doki_doki]thanks i'm still waiting for my order of the softest rrr evo springs to arrive right now, i'm using the kyosho silver springs which is the softest spring that i used for my rrr wce. still, the rear end still no that planted on power [/QUOTE
Check your diff & what weight are you using
#8227
#8228
[QUOTE=710baby]
What-up, George!? How ya' been, Hommie?
#8229
How much rear toe-in are you running? Also, what shock oil weight are you using?
diff: 50,000wt/20,000wt
shock oil: 50wt/50wt
springs: blue/silver
shock position: 2nd/4th from bottom
toe: 1 deg out/2 deg in
camber: 1 deg/3 deg
swaybars: removed/removed
tires: 40/40
tracks: technical with fair grip (a bit bumpy)
ride height: 5.5/6.0
#8230
front/rear
camber: 1 deg/3 deg
tires: 40/40
camber: 1 deg/3 deg
tires: 40/40
Tires will solve the majority of handling problems. Have you tried 42F?
#8231
front/rear
camber: 1 deg/3 deg
tires: 40/40
camber: 1 deg/3 deg
tires: 40/40
#8232
..If, you haven't already, remove the spacer under the rear camber link and use the outer hole on the bulkhead mount. ...
a question on the above sentence. this is going to change the roll center? and will lower it or make it higher?
antony
#8233
front/rear
camber: 1 deg/3 deg
tires: 40/40
camber: 1 deg/3 deg
tires: 40/40
Just my opinion.
#8234
Originally Posted by antoine80
hi all
antony
antony
#8235
It will lower your roll center, therefore increasing the distance between roll center and CG, allowing more weight transfer and ultimately more grip to the outside rear tire through a corner.
