Kyosho v-one rrr
#8011
Originally Posted by joemugen
just want to let anyone who is looking at the ebay listing for a rrr that is is NOT a rrr.... be aware, looks like a scam to me
http://cgi.ebay.com/Kyosho-Nitro-1-1...em140028529191
#8012
race
Originally Posted by rmdhawaii
Congrats to Dom and Mike on their 1st and 2nd place finish.
Will! Bring it home! You know you can do it! R/C Pro Series race #4 was a preview of your full potential. Show 'em what you got bro! RRR all the way!!
#8013
Is it normal to hear electronic noise (soft) when turning on of the RX connected wif servo units?
Anyone have any advise how to set the servos correctly in neutral position or wat do u mean by setting it to neutral? using Futaba 3pk. Both servos are futaba s9451.
#8014
rear camber links..
hey guys
im trying to under stand the rear camber link a little more
i have my car handling awesome but the rear camber link doesnt seam to be strong enough, always after races i find the rear camber link bent, like the turnbuckle isnt long enough..
what effect would moving the rear camber link to the outerhole give ? im using the original rear camber link.
i find with my camber angle of about 3.5 degrees my car works best
thanks
thanks
#8015
Originally Posted by mrgsr
hey guys
#8017
rmd..the track i race on has good grip but the surface has not much side bite..
with -3.5 camber on the outer tyre im still getting positive camber wear on the tyres..and i also get a bit of slide mid way into the corner.
should i move the camber link position to the outer hole (the hole closer to wheel) ??
#8018
mrgsr: Just try it and see what happens!
Here are some longer 4mm turnbuckles...
https://www.lunsfordracing.com/mm5/m...egory_Code=4MM
#8019
Dom
#8020
Mrgsr,
If you're still getting positive wear at between -3.5 and -4 Degrees, then I would suspect that the tyre rims are too soft. Which tyres are you using?
Cheers, Mark.
Cheers, Mark.
#8021
ianhobbies: Guess what I found??
http://www.kyosho.com/blog/rc/
Use this to translate: http://babelfish.altavista.com
#8022
Does anyone know who all of these guys are in this photo?
http://210.253.122.57/blog/rc/log/im...06090059_1.jpg
#8023
Location: Costa Del Sol, Marbella, Spain www.bradir.net
blog
tnx man! tnx for the time.. it has pics ..
#8024
pics
well i think the most important guy is the one below with the black shirt.. coz he's the designer! he's like the adrian newey of RC!
#8025
Can this Sanyo Nimh 6v 2500 mAh Rx battery pack support Futaba R203HF Rx and 2 nos of Futaba S9451 Servos?
