Kyosho v-one rrr
#5896
http://www.parmapse.com/10219_sell.jpg
Guys I will be testing this body at Ft.myers at the end of the month....I will let you know how it goes
#5897
Originally Posted by rmdhawaii
I purchased $108.00 worth of expensive rear 0mm offset wheels without knowing that the kit rear wheels had a +2mm offset - and raced with a 198mm track-width...
Originally Posted by tommi
It's 196mm...!
Kudos to rmdhawaii in taking the effort to compile all the info, an FAQ maybe?
You guys willing to help with the info? I would be willing to setup the site and maintain it.
#5898
#5899
When I put it on the setup board, it read 198. Must have been the camber.
Thanks. I've been thinking about creating a V1RRR Resource Web Site - Knowledge base, setup, links, optional parts, reviews / tests, FAQ, etc. It would make like easier for everyone - and you wouldn't have to sift through all these pages trying to find the information you are looking for, but it sure would take a lot of work. Plus I only own the WCE! Hmmmm...
sounds like a great Idea I will give you as much info as possible thats no prob
#5900
Originally Posted by B4
Has anyone tried the new Serpent 710 shocks on the RRR.
Do they fit ?
Do they fit ?
RC_Alan
#5901
Originally Posted by rc_alan
I'm running the Serpent RCC shocks on my RRR... They don't leak and they're super smooth too... If you have the old Serpent shocks, stay with the Kyosho.. but if you just so happen to have the RCC shocks laying around... used them... Depending on track conditions.... I'm using the Serpent red springs in the Rear... Sanded all the red paint off though and Kyosho black springs in the front... Oh and I think someone asked about the K-Factory UFO clutch... I have one as well... It's a toss up between the stock clutch and UFO... Both work great... You can use the kyosho clutch gears on the K-Factory clutch bell or use the K-Factory ones... There gears are more durable
RC_Alan
RC_Alan
#5902
#5903
I had that same shock problem on my kyosho offroad car I sanded the top of the shock body with fine sandpaper and then I could tighten them up without damaging the bladders.
I have been reading all this offset stuff and I remember when the mtx3 came out I got one and we had this same problem.
#5905
Just a little info on leaking kyosho shocks.....if they do leak chances are you have tightened them down to far and damaged the bladders...I have corrected that problem with my shocks...I used to crank them down......but you dont have too once they are snug they will not leak...
RC_Alan
#5906
Originally Posted by maskedrider
Hey Tommi.... beri Chim leh...
catch no balls....
catch no balls....
#5907
I'm using the Fantom rear springs on our Front and the Rear and using 50 shock oil for both... result : veri stiff and it handles well especially on width track and long stright
#5908
Originally Posted by jag
The Serpent wheels are 0 offset.
If the shim is good enough for Josh, it's good enough for me.
#5909
#5910
Is there a successor in sight for the RRR? I'm really tossed up between these two cars (MTX4), but I always tend to come on the later span of a car's lifespan. The CE is cheaper than the 4 by $25-50. I cannot get parts locally for either car.
