Kyosho v-one rrr >
Kyosho v-one rrr
Kyosho v-one rrr
Old 03-25-2006, 09:00 AM
  #5551
Osiris 75's Avatar
Trader Rating: 18 (100%+)
Originally Posted by 710baby
If you like the Turbo 3 another pipe which is highly recommened for mid range track is the team version which was the 62505 but has changed since the added the reinforced stinger I will post the # later I will be testing out the new version tomorrow the turbo3 is more for a large track with a big straightaway
Ok, thanks!! I guess my local track is small to medium...
Osiris 75 is offline
Old 03-25-2006, 11:01 AM
  #5552
rmdhawaii's Avatar
How does a person determine what pipes fits what type of track? Is there a guide somewhere?
Thanks!
rmdhawaii is offline
Old 03-27-2006, 04:33 AM
  #5553
mcsquish's Avatar
Yes, is there a guide somewhere? I have a X12 and run on a track that is either in the big to really big catagory.
mcsquish is offline
Old 03-27-2006, 04:51 AM
  #5554
jag
jag's Avatar
Default Tank
Does anybody know how the gas tank is put together? Is it heat welded, glued, chemical fusion, etc...
I have a tank that leaks all the way across the front seam. Is there any way to fix it?
Thanks.
jag is offline
Old 03-27-2006, 05:07 AM
  #5555
picco007's Avatar
Trader Rating: 99 (100%+)
Speaking of pipes, I have an OZ TZ with a RD logic turbo 3 pipe. We usually race on a small track 155 x 75. What pipe would be recommended? I bought a rd logics 505 but haven't used it yet. Someone told me the 505 is like the skyline vr12, can someone tell me if that is true?
Does anyone have recommendations?
picco007 is offline
Old 03-27-2006, 05:08 AM
  #5556
JustRace's Avatar
Thanks.
Use a soldering iron and repair the seam. But you're better off replacing it.
JustRace is offline
Old 03-27-2006, 05:40 AM
  #5557
maskedrider's Avatar
agree
maskedrider is offline
Old 03-27-2006, 06:23 AM
  #5558
jag
jag's Avatar
I did and I am... hopefully today if I can get down to Go Racing.
jag is offline
Old 03-27-2006, 07:45 AM
  #5559
rmdhawaii's Avatar
I'll post something in the main Nitro On-Road thread to see if we can get some answers.
Old 03-27-2006, 12:26 PM
  #5560
GMartinez's Avatar
Trader Rating: 91 (100%+)
I tested the 62505R which is the pipe you are talking about it is a balanced tuned pipe for a 12-15 engine the tuned pipe works perfect on a big flowing tracks with alot of sweepers testing was done @ kissimee raceway the turbo3 is also great on big tracks with a long straightaway it works better on a track that does not have a lot of sweepers like the track that is in Fort Myers as for the skyline comparision to rdlogics there identical it is very hard to to say which is better they feel the same.
I would recommend the 505 for your track since it is smaller than the track i raced @ & you will feel that has a bettter midrange than the turbo3 and the turbo 3 has a better topend on the straight but might be 2 much for that track do the testing & let me know what you think.
GMartinez is offline
Old 03-27-2006, 12:32 PM
  #5561
GMartinez's Avatar
Mcsquish are you talking about the toledo track where the GLC is hosted.
If so I ran the Rdlogics turbo2 & then switched to the 505 pipe to gain more midrange speed there lastyear . Hopefully I can make it again this year.
Old 03-27-2006, 01:10 PM
  #5562
Osiris 75's Avatar
What gear ratio's do you guys recommend on a small track?? I'm just using the ones that came with the kit. Is that good enough??
Old 03-27-2006, 07:41 PM
  #5563
GMartinez's Avatar
should be fine with the stock if you have any runtime issues you can try 17/23p 56/61s
Old 03-27-2006, 08:17 PM
  #5564
dougday's Avatar
For small track, change your pinion gears to 15 & 20
dougday is offline
Old 03-28-2006, 06:08 AM
  #5565
jag
jag's Avatar
How small of a track? I find the stock gears to be pretty good on my small track (75' x 150').
jag is offline
