Kyosho v-one rrr >
Kyosho v-one rrr
Kyosho v-one rrr
Old 01-26-2006, 12:41 PM
  #4786
impalabob64's Avatar
Default milled out chassie for rrr
hey guys anyone seen the prototype chassie for the rrr it like serpents new chassie .lmk
impalabob64 is offline
Old 01-26-2006, 04:23 PM
  #4787
GMartinez's Avatar
Trader Rating: 91 (100%+)
Saw it in october friend bought it from overseas looks really good
GMartinez is offline
Old 01-26-2006, 07:02 PM
  #4788
V1-RRR-WC's Avatar
Ok,
So I am now getting around to tuning my chassis and want to make sure I understand what I am reading is correct.
Is the rear toe on the stock setup +2 degs?
Would this not cause the car to be very unstable under normal circumstances?
Also, is it just me but to be able to get the rear track to 200mm, the drive shafts just bearly fit into the outdrives???
Looking forward to any confirmation on this.
V1-RRR-WC is offline
Old 01-26-2006, 07:07 PM
  #4789
Trader Rating: 15 (94%+)
the rear toe should never be positive
start with -2
my local track is pretty low traction so i tend to use -3 toe in with -3 camber.
mrgsr is offline
Old 01-26-2006, 07:13 PM
  #4790
V1-RRR-WC's Avatar
start with -2
Hi Mrgsr,
This is what I know. But I clearly see +2 degs on the setup sheet. Can anyone else confirm this is what the stock setup sheet has?
I just want to make sure I am noting going blind already
Old 01-26-2006, 07:58 PM
  #4791
GMartinez's Avatar
Originally Posted by V1-RRR-WC
Hi Mrgsr,
Same here on the set up sheet I just checked mine & must be an error
Old 01-26-2006, 08:27 PM
  #4792
AndyT ©'s Avatar
Ok,
Are you using offset wheels....these should take the trackwidth to 200mm
Cheers
AndyT © is offline
Old 01-27-2006, 03:22 AM
  #4793
V1-RRR-WC's Avatar
Hi 710baby,
So what did you start off with? -2 deg?
Please let me know.
AndyT,
Ok, thanks!
Old 01-27-2006, 08:02 AM
  #4794
jag
jag's Avatar
Has anybody had trouble opening the pdf files from the Kyosho website for the RRR WCE? For some reason my computer is getting an error. It says something about a missing or corrupt decoder for a font. When I do get the file open it has no text.
Thanks,
jag
jag is offline
Old 01-27-2006, 09:11 AM
  #4795
JustRace's Avatar
Thanks,
jag
No problems here.
JustRace is offline
Old 01-27-2006, 09:42 AM
  #4796
jeffreylin's Avatar
Thanks,
jag
You need to download the Japanese language component of the Acrobat Reader. Make sure you have the latest version of Acrobat (www.adobe.com) and it will download for you automatically.
jeffreylin is offline
Old 01-27-2006, 11:14 AM
  #4797
jag
jag's Avatar
That worked.
Thanks.
jag is offline
Old 01-27-2006, 01:44 PM
  #4798
hey my rrr kit is ariveing in a few days is there any handy tipsor hints u guys can tell me about building this kit?
thankyou.
ShAfTy is offline
Old 01-27-2006, 01:46 PM
  #4799
whats up jeff. what do you think so far between the rrr and the mtx-4. basically, no advantage to having either one over the other???
Joe Chaplow is offline
Old 01-27-2006, 04:55 PM
  #4800
robert maestrey's Avatar
thread lock set screw that holds down 2 speed on to the main shaft. also you should thread lock the screw that goes into the ball that attaches the mixing lever to the linkage that goes to the throttle server.
robert maestrey is offline
