Kyosho v-one rrr
#4231
Originally Posted by wad
Hey Peter!!
When are you coming back to racing?
I will need your help now
#4232
Originally Posted by Racing4Evo
Did they give you a car yet? I may be able to go Sunday, I will let you know. PM your phone number.
#4235
I haven't raced in a while. I don't think I could compete with any of you guys now.
#4236
#4239
Yeah, supposedly it has a big ass pikachu painting all over it.
#4241
hi guys,
newbie question, im thinking of getting the WC edition kit, is this already coming with the SP chassis? what other hop-ups are in this kit which are not in the standard kit? and what additional hop-ups do i need to get to make it run better but not so much on the wallet...
thanks
K6
thanks
K6
#4242
hi guys,newbie question, im thinking of getting the WC edition kit, is this already coming with the SP chassis? what other hop-ups are in this kit which are not in the standard kit? and what additional hop-ups do i need to get to make it run better but not so much on the wallet...
thanks
K6
thanks
K6
universal cvd's all around,
carbon fiber front shock tower (has 3 holes so more adjustments),
SP battery plate,
side belt tensioner w/ SP plate,
lightweight gear housing,
1 piece engine mount,
also bearings on servo saver and throttle linkage instead of bushings...
Alum brake stopper
SP drive belts
Alum muffler stay
The only hop up that u need is rear shock tower..skyline make a great shock tower, it's 4mm thick..the stock one is only 2.7mm. It's also good to stock up rear outdrives, they wear out pretty quick.
i'm sure there's more things that i've missed, but other than that they're everything i mentioned above. You can't go wrong with the car, the stock setup works good already. Hope this helps and good luck
#4244
Originally Posted by luketob
I don't think there's a different in chassis, but WC comes with:
SP battery plate,
Alum brake stopper
SP drive belts
Alum muffler stay
SP battery plate,
Alum brake stopper
SP drive belts
Alum muffler stay
K6
#4245
where can I get some parts or even the car on-line for cheap?
Thanks guys!
Thanks guys!
