Kyosho v-one rrr
#4201
is the 3mm chassis an option or the chassis that comes in the kit?
#4203
whats up jeff,
i use the 4mm rear shock tower. but do you think the 3mm shock tower would be better for handling purposes? what i mean is that the 4mm shock tower stiffens up the rear end a lot, kindof how the 4mm chasis stiffens up the entire car. maybe with the 4mm shock tower you lose a little of the flex that the rrr has, which i think is one of the things that makes the rrr so good. food for thought, what is your opinion?
#4204
Originally Posted by joemugen
whats up jeff,
#4205
The chassis links the frond and rear ends of the car together. It playes a MUCH bigger part in the cars handling.
#4206
Pretty obvious really. It also gives you place to put the motor, tank and radio gear....
#4207
Originally Posted by dmastroy
This is what happens to you when you drive a RRR very fast....
(check foto)
(check foto)
[IMG]PodioSenior.jpg[IMG]
#4208
Originally Posted by geeunit1014
i am looking to get this car for xmas. are there any parts prone to breaking more often thean others like the rear shock tower on the mtx4 does?
#4209
Originally Posted by mariochi
and this......
#4210
if you have been waiting to receive your RRR WC, your LHS should start receiving them in the next days or so. If your hobby shop does not them have on order, let them know Kyosho does have them in stock.
#4211
what pipe would you guys reccomend for a os tr12 turbo on a short to medium size track(140ish feet)
#4212
#4213
Originally Posted by MRX_joe21
Skyline VR12
