Kyosho v-one rrr
#1876
Originally posted by DaRollaRacer
Is the WC rear shock tower an upgrade in quality where it's less prone to breaking when compared to the regular RRR?
Dave
Dave
#1877
RRR SIDE BELTS
Hey guys
Can anyone help..
Ive been running my RRR sence last year. And i never had any problems with my side belt. I would have problems with my
front or rear belt before my side belt. But this year i decided to
change my side pulley from 23 to 24Teeth, and i run no split on my tires.
I would say that after 30min of running my side belt is missing teeth. Not just 1 or 2 here and there, but sections of teeth are missing. Does anyone know why is that.
Can anyone help..
#1878
Re: RRR SIDE BELTS
Originally posted by GUINT1
Hey guys
Can anyone help..
Hey guys
Can anyone help..
#1879
Re: Re: RRR SIDE BELTS
Originally posted by jeffreylin
Maybe you are running them too tight?
But i have about 10 pack of side belts. all with the same ordering
number. some seem to be looser or tigher than others why?
#1880
Re: Re: Re: RRR SIDE BELTS
Yes... it does feel tighter.
#1881
Re: Re: Re: Re: RRR SIDE BELTS
I think there is a different belt if you want to run 24T front pully.
#1882
Re: Re: Re: Re: Re: RRR SIDE BELTS
Yes there might be a different belt, but how or do you have a ordering no# for the larger belt?
#1883
Re: Re: Re: Re: Re: Re: RRR SIDE BELTS
VZ 237 side belt 387 (instead of 384)
#1884
Re: Re: Re: Re: Re: Re: Re: RRR SIDE BELTS
thanks a lot kid. that should help me a lot.
BTW, you can get a lot of info if you just check their web site:
http://www.kyosho.co.jp/web/products...p_other-e.html
#1885
Re: Re: Re: Re: Re: Re: Re: Re: RRR SIDE BELTS
kid? there is a good chance i am older than you.
#1886
Originally posted by ATOMIC
The WC tower just has extra wholes still pretty weak at the body mounts.
#1887
#1888
Originally posted by joemugen
one main reason this happins is when you are stuck against a wall and give it gas to get out, you tear that belt up. if you are stuck against a wall, wait for a turn marshall. i know it sucks to wait, but if you do not you will ruin belts.
THAT IS SO TRUE.
ALSO HAVE YOU USED THE TWEAK STATION.
HOW DOES THE TRACK WIDTH WORK.
#1889
THANKS JOE
THAT IS SO TRUE.
THANKS JOE
THAT IS SO TRUE.
