Kyosho v-one rrr
#1681
Originally posted by joemugen
you going to naples?
#1683
Originally posted by JustRace
Not sure about Naples. Definately not on Saturday. Might go on Sunday.
#1684
also, when i am at a stand still and give it gas it shifts to the left. that might be a bearing???
See the article here from Julius about building the rear diff correctly.
#1685
Originally posted by Grinder
Yes, they are MRX4 shocks. I liked the Kyosho shocks, but they leaked, even after a rebuild they soon leaked. I put the Mugen shocks on and have not had to do a rebuild yet. A friend of mine put the Mugen bladders in his Kyosho shocks. He said it fixed the leak.
#1686
Originally posted by Racing4Evo
The front is the same as the regular RRR meaning you use 0 deg. offset wheels. The rear on the other had requires 2 deg. offset wheels to make width. It's just the universals that are causing this. You can replace them with the normal ones that include a 2mm spacer, use 2 deg. offset wheels or insert a 2mm hexx spacer between the hex and wheel.
#1690
Front Diff Problem
Last sunday, I destroyed the plastic part that makes the front diff a solid one. I ordered it but I haven't reveive it yet. In 5 days we have the first race for this year's championship.
What can I do? Is there a way to convert the one way diff to solid with out ruining it? (our track REQUIRES a solid front diff!!!)
If there is not any other way, how should I convert it to solid for sure?
Thanx for your imediate replies!!!
P.S. Gia sou Foti!!!
#1691
I hope your ordered the 3racing aluminium one! The plastic one is no good
Cheers
Cheers
#1692
Originally posted by jeffreylin
They do wear out pretty quick. K factory has the hardened pinion that will work for 2nd gear but no one that I know makes the smaller ones for the first gear.
15, 16 and 17T
Cheers
#1694
Re: Front Diff Problem
victory taste good
#1695
