Kyosho v-one rrr
#1636
2
sweet ride Grinder
sweet ride Grinder
#1637
Aren't those Mugen springs in Grinder's car?
#1638
#1639
Originally posted by rfy
Hi Grinder,
I experienced a lot of diff to left front bulkhead binding when I tried putting in a spool..does any part require some modification to fit?
Anyone's 2 cents will be appreciated!
Hi Grinder,
Remember on of the first steps in the assembly, using C/A glue to attach a rim on the oneway pulley???
Well, you either have to remove it with Acetatone(I think that is what you call it), or buy a new pulley!!! Also you have to use a few 3mm shims or a 3mm locknut to lower the ball-ends on the steering arm (in order to prevent them from hitting the dif case) and change to the 12 ackerman!!!
#1640
Originally posted by SpeedsterRRR
From what I gather, this is your problem:
#1641
#1642
thanks SpeedsterRRR..that did it!
#1643
anybody know exactly what the new 1 and 2 degree front hubs do?
#1644
#1645
Super Moderator
Originally posted by Grinder
Yes, they are MRX4 shocks. I liked the Kyosho shocks, but they leaked, even after a rebuild they soon leaked. I put the Mugen shocks on and have not had to do a rebuild yet. A friend of mine put the Mugen bladders in his Kyosho shocks. He said it fixed the leak.
#1647
Well, guys, I emailed Pro Shop in Japan and they're out of WC kits. Anyone know where else it's available? I REALLY want that kit
Dave
Dave
#1649
Dave
Dave
#1650
Yes, they do have but they are so much more expensive than that of their Japanese counterpart. Is there another Japanese shop I can get the WC from?
Dave
Dave
