Old 08-26-2004, 02:23 AM   #1
Default NTC3 clutch + kawahara's pinions
Hi all, I've a question for for the pro drivers, is it possible to put the kawahara's pinions on the standard clucth from the ntc3, because I look for any bullet proof pinion for my car, the anodized pinion from Team Associated are so bad... Thankx
P.S: sorry for my poor english
february is offline   Reply With Quote
Old 08-26-2004, 11:36 AM   #2
Solara's Avatar
Trader Rating: 16 (100%+)
honestly, that is unnecessary............my NTC3 pinion gear are chipped and scrached and whatever (doesn't look good at all) but when they are spinning, they are still work like the first day I have them in my car.....
You don't really need to replace some bullet proof type of pinion on NTC3...
Beside, you CANNOT use kawahara or Hongnor or Mugen or anohter centax type of gear onto the NTC3 clutch...won't work.
Old 08-26-2004, 01:15 PM   #3
ZipZap's Avatar
Default Kawahara gears
The kawahara centax made for the NTC3 uses the same 1st gear pinion sizes/threads as the associated clutch bell, so 1st gears are interchangeable. 2nd gears on the kawahara have a larger i.d., so they are not interchageable.
ZipZap is offline   Reply With Quote
GT2 to NTC3 clutch ????? Heynow2373 Nitro Off-Road 0 11-17-2007 02:05 PM
How do you remove the pinions off the clutch bell? Ryan41 Nitro On-Road 14 04-11-2007 01:03 AM
Need Help With Ntc3 clutch! serpentsixty9 Nitro On-Road 5 07-17-2004 08:34 PM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 04:01 PM
ntc3 clutch umbe Nitro On-Road 5 06-02-2002 11:24 PM
SEO by vBSEO 3.5.0
