Old 08-23-2004, 04:27 AM   #1
Project D's Avatar
Default Help!!!
my pull start string came out... i cant start my engine this way...and my servo is weak in turning... how???
Project D is offline   Reply With Quote
Old 08-23-2004, 07:46 AM   #2
You will have to unscrew the 4 screws on your pullstarter, as you start to unscrew them the string to the pull starter should go back in automaticly.
If it doesn't then you need to get a new pull starter and put it on. Its very simple to remove and add a new one.
If your steering servo is weak, it might be your dual rate. There is a little nob on your radio controller that controllers how fast or slow the steering servo turns.
J Smith is offline   Reply With Quote
SEO by vBSEO 3.5.0
