Help with Kawahara Negative diff
Hi all
I am halfway thru building a negative diff. And I can't work out where the red o ring goes.
Can any body help.
Thanks in advance.
Can any body help.
Thanks in advance.
Neg Diff
what car is the diff for???
Re: Neg Diff
MTX-3
For a MTX-3 Thanks
neg diff
you should have 2 red o rings.
put the first one in right before the gears .
o ring - shim- pin-now gears.
now gasket-gear-pin-shim
Hi, what does the negative diff do exactly ? how much different is it from the one that comes with the kit ? when do we use it ? Thanks !
it only came with one oring.
I used the standars one's in the spots where you said.
Not sure what they are used for but I noticed sirakarn had one in his car when he was here a few months back.
The O-rings are intended to stop the diff oil escaping from the diff. It can seep along the output shafts and onto the clutch shoes.
Here's a pic of the V-One version, but I expect the principal should be the same.
neg diff
When youre putting the O-ring in. It feels tight, like its to big.
Thats OK.
oh! gosh! You DID color that very nicely...
Re: neg diff
sorry for this, but I couldn't stop thinking and LOL that this might be how my wife thinks of it, " It feels tight, like its too big."
sorry, sorry...
sorry, sorry...
Yes this is correct.
Thats OK.
Thats OK.
As long as your wife doesn't lock up on exit, it's all good.
