New 1/8 on-road "XR8"
#512
Thanks Nick! By the way, it wasn't my 'pit guys' fault.. The starts were &%*#@#-up! Could not here the pa over there and the flagman was a fantom!
Found one thing wrong with car.. tank lid quit sealing! That was the cause of the wetness & extremely high rpm run-on (not to mention my lack of brakes in main).
Carnage, you have to check out the last item on the grid on-road forum! I have got to get me one of those!
#513
In Europe PROTECH brings the car on the market
it's the "VXR-8" and the "VXS-8"
For what i've heard, they are not very strong.......
#514
"In Europe PROTECH brings the car on the market
For what i've heard, they are not very strong......."
Got any links to back this up. I've proven to myself this car is plenty strong. I had a pair of near identical crashes, same place, different cars. The R40 needed a new chassis, front bulkhead, 2 front shock bodies, ect. With the XR80, I bent the bumper back, and poped the body back out. These cars are plenty strong...
#515
strength
#516
Both crashes were, of course, accidents. The reciever died in the R40, leading to a near full throttle impact. The XR80 had a battery wire come loose, sending it in at about the same throttle setting, and a little more speed. I rarely crash, and it's been a mechanical failure each time. I've ovebuilt it now, should be strong enough to handle any number of "accidents". The one thing that's been a problem recently, was the tuned pipe. It's the crappy old rubber coupler type. It has a tendancy to pop off in race collisions. I replaced the R40's pipe with the spring attached coupler, big improvement. I plan to do the same with this one. I may try a few tricks in the mean time to keep it on there...
#517
The cars you see here in Holland are, SMP, Serpent, Kyosho, Mugen, Shepard.....
The problem was that the suspension wears out to fast, with the result of unwanted movement in the parts.......
Also the front suspension is more like the S950, and Serpent changed this for strength reasons with there S950R kit......
I can not back up this story with pictures of any kind, it's just something I've heard........
another problem is because the kit is only about $100 cheaper then the "big" brands, people tend to stay with what the know......
#518
I, too am a racer, not a basher. I run the XR8, not the XR80. My XR8 has less slop in the suspension components, after a couple of hours track time, than my Kyosho did when it was new! Long term durabillity, well, we will see.
#519
Suspension
Since we are on the subject of suspension components, you also have the option of using the new MC Nylon suspension upper and lower arms for the XR/8.
http://happytimehobby.com/catalog/images/x82035.jpg
All pieces are CNC cut for percision and performance.
#520
It's good to hear constructive criticism, and aparently there's a cure to that issue. I like hearing how well the car has done in large events, up against all those nice cars you listed. I bought the RTR, wich when compared to the other brands, is a fantastic value. Put simply, you cannot get into 8th scale for under a grand, unless you get the XR80. That's an easy $600 cheaper than the next cheapest competitor, when you add up the motor, pipe, control system, and starter box. You end up spending around $1500 on a Serpant, MRX, ect...
#521
durability
#523
Originally Posted by revzalot
What shore combinations are XR8 racers running?
