Good servo for 1/8 onroad??
Used to use Sanwa ERG-VZ, but it seems to be discontinued product. Looking for good servo's to my brand new MRX5-car. Any suggestions? Maybe I'm wrong but it looks likes that the new Sanwa servo's are not giving as good tech specs than the old ones (13kg/0.10sec). What would be the VZ replacement from the new ones?
Or would it still be wice to try to find a couple of VZ-servos and go with them? -X- (-1C and raining ice-cold water today here) |
I'm also amazed by the current Sanwa line of servo's.
They used to have servo's with speeds of around 0.06/0.07 seconds but now they all are around 0.10. Even the supposed to be super fast SRG servo's are 0.10.:confused: They claim the SRG technology makes them a lot faster but they don't give you any numbers on how much faster they are, plus I don't think this technology can make up for 0.03 seconds. I'm currently looking at some Kopropo RSX servo's, super fast, a lot of power and you can connect them straight to a Lipo. I only hope Kopropo will make a low profile version pretty soon. ;) |
These are actually pretty damn good for the money:
http://www.hobbypartz.com/60gexidised2.html Unless you want to pay top dollar for the very best, its actually hard to go wrong with this one. |
i would recomend the vortec by team orion its like 90 bucks but well worth it trust me i run it in my mrx5 it does, speed is .09 with 200oz torque!! the other one they just posted only had 111 oz torque for onroad u want alot of torque in the steering for on road and there made by savox!!
If you are looking for indestructible, strong and cost effective than look no further than Hitec they have the new high voltage premium digital that can handle lipos without a regulator (you know everything is going to lipo)
Take a look at the TH-7940 has a .06 speed on lipo TH-7945 has a 300+ oz. in. of torque Titanium gears !! |
SAVOX SC1258 !!!!!!
KO Propo RSX 30100 and 30101. Works great with Sanwa m11x radio.
http://www.kopropo.com/america/index...=31&Itemid=176
Ko Propo RSX Power: Throttle VOLTAGE: 6V or 7.4V TORQUE @6V: 362.9 oz-in, 26.3 Kg-cm TORQUE @7.4V: 436.1 oz-in, 31.6 Kg-cm SPEED@6V: 0.13 S @ 60° SPEED @ 7.4V: 0.11 S @ 60° BEARINGS: YES, DBL LEAD CONNECTOR: GOLD PLATED GEARS: FULL METAL WEIGHT: 65.6 g For Steering then RSX Response VOLTAGE: 6V or 7.4V TORQUE @6V: 362.9 oz-in, 26.3 Kg-cm TORQUE @7.4V: 436.1 oz-in, 31.6 Kg-cm SPEED@6V: 0.13 S @ 60° SPEED @ 7.4V: 0.11 S @ 60° BEARINGS: YES, DBL LEAD CONNECTOR: GOLD PLATED GEARS: FULL METAL WEIGHT: 65.6 g I have tried these servos and have KO servos in my car, I have been runnning non stop for 4 years straight and Never a Problem. A little expensive but worth the extra money:D Hope this helps |
I love my futaba s9351's they are so precise.
Originally Posted by MRX4XXXX
(Post 8507902)
If you want to save a few bucks. SAVOX is a decent option.
Originally Posted by JIM1
(Post 8511030)
SAVOX SC1258 !!!!!!
The Savox SC-1258 is very snappy but it draws a bit more juice than the Futaba BLS servos.
I think the OP needs to give a price range first ,then people could give better input
Thanks for everybody. It's nice to see that I'm not alone thinking about these things...
The price range is somewhere in the VZ-SRG area. The RSX-level hurts a little bit too much. Second, you have to always remember that it's the total cost that counts. If something fails, (receiver, battery, throttle servo), I will loose the engine at the same time, in the worst case scenario... -X- (-3C and snowing today) |
