Engine question !!
Could anyone tell me the difference between engines that have something -------(Threaded) & (SG) ------- sorry for the newbie questions but my engine is in need of rebuild and I am wanting a new engine too.
Could anyone tell me what the standard novarossi (.12) for 1/10 is. Threaded or sg thanks, James:tire: |
Pretty much everything is SG now.
threaded is also called an OS shaft. the part of the crankshaft comming out of the engine is only threaded. With a SG there is some thread and on that a 5mm shaft on which you can mount the compleete clutch, with threaded you need an adapter shaft to mount the clutch.
I believe some .12 (side exhaust) Novarossi models can still be bought with a threaded shaft but most engines do come with SG. Do you have a special clutch with an own adapter you can cut off the 5mm shaft making it a threaded shaft. |
