Setup For G4
Setup For G4
I need someone to help me to setup a g4 for med size track, med grip. ex. diff oil , spring,shock postion, caster, and camber
Thank you
Thank you
Try this for your basic setup :
diff oil :
10.000
shock oil : #400
spring : G4 purple
piston : standards
shock position :
front : 2nd inner-most (K-Factory shock tower)
rear : 2nd outer-most (K-Factory shock tower)
downstop :
front : 1
rear : 4
tire shore :
front : 40
rear :37
castor : standard
camber :
front : 2.5
rear : 4.5
diff oil :
10.000
shock oil : #400
spring : G4 purple
piston : standards
shock position :
downstop :
front : 1
rear : 4
tire shore :
front : 40
rear :37
castor : standard
camber :
front : 2.5
rear : 4.5
