Capricorn LAB C801 1/8 scale
#856
Almost done!
#857
More off power steering
Hey guys, so during my last race I had I tried getting more off power steering but the only way I managed was to run a 2 split shore difference (softer upfront).
Really liked the way the car handled off power but unfortunately the front tires didn't survive the 40 min race. at the 30 min the front was scrubbing all over the pace once I hit the slightest amount of brakes.
Was running chrome spring all round, thought of running black spring or progressive black spring in the front.
What do you suggest?
#858
your lap times will show it to
At our last Series race 30 min final. At the 20 min mark I could tell the car was in need of tires but I was controlling my pace and conserving tires. (Just like F1)
anyways I lose almost 1 second per lap at the 20 min mark, smaller tires and costing around the track saving tire in case i have to speed up, If i was to pit at that point I would lose 15 seconds between coming in to stop and fuel and tires, it would take me 15 laps about 4 mins and 30 seconds to catch that back up and then I would gain a lap over the last 5 mins.
If no one else is pitting I dont bother to stop because there pace isnt going to be any better, everyones car is getting slower
Or plan your tire size better.
I ran 32 Fronts 35 rear
75.5LR 75RR 68LF 68RF
My left rear had the most ware down to 68.2
To get these tires to last 40 mins I would have to run 37 fronts and 40 rears and the car would just be so far off the pace, even 35f 37r would slow the car enough that a pit stop and soft tires would be much faster
I hope that this info helps you out some
#859
Unless you run harder tires or the ware rate is low anything over 30 mins a tire change is needed
#860
Ready for Run !!!!!
#862
Thank you!
No one MX 21 MAX XL7
#864
Roll over bar / handle
Hey guys, which brands use the same handle bar?
#865
#866
1st and 2nd shaft - bearings and 2speed stripping problems
Dear all,
Last Saturday i started stripping 2nd gears once again. Already had this issue a couple of months ago and found out that the screws in the rear bulkhead that fix with the main shaft towers got loose so it was causing too much flex.
Fixed the screws and problem solved.
Lately i noticed that the bearings that hold the main shaft especially the one on the 2speed where getting busted after a 30 min race.
To make it worse last Saturday i stripped 2 x 2nd gears, i thought because of the failed bearings but still they weren't that bad.
I also noticed that the 2nd wobbles so much that its touching a bit the swaybar?
What do you guys suggest?
#867
Dear all,
Still can't understand why the bearings are getting busted so easily.
I also noticed that there is quite some tension on them because of the rear belt, is this normal, mine is set like the manual says i.e. default.
#868
Difference between Main Shaft Collari Edition & Hard Coated
What the difference between these shafts, from the product code looks like the Collari edition is the 3rd one as it has a C at the end of the part number.
Which is best in order not to have problems with the bloody one way.
#869
Latest and best is CAP 2020C and use it with the CAP 2058B one-way. You should not have any problems with this combo.
#870
