Old 12-04-2010, 01:36 AM   #1
Default please help my novarossi sleve pin has dissintergrated can i put a new pin inside
Hi I'm thinking of getting piston and sleeve set for my nova rossi collar engine but the problem is u know the pin that keeps the sleeve inside engine in position it dissintergrated inside engine is there any idea how I can put another pin inside or is there any idea were I can go to get a pin fitted.or do u think it will be ok to run without pin cheers
kyoshoevolvam3 is offline   Reply With Quote
Old 12-04-2010, 05:07 AM   #2
It is physically impossible to run an engine without the pin!! You may as well take out the piston and only use the connecting rod!
You could use the whole lot without the retainers/c-clips, but you risk a certainty of the pin moving sideways and ruining the sleeve.
If possible, give it to somebody that knows what they are doing, and let them reassemble/disassemble the engine so you know for sure nothing will go wrong! Id say send it to me, but I live a looooong way away from you!
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
SEO by vBSEO 3.5.0
