Questions on getting a Starter Box >
Old 07-27-2004, 03:43 PM
Default Questions on getting a Starter Box
I was thinking about getting this Ofna 1/10 Starter Box for my HPI RS4 2 and it says that it uses a 12v battery. What type of chargers can I use to charge the 12v battery?
http://www2.towerhobbies.com/cgi-bin...&I=LXAXU2&P=ML
Could I use a SuperBrain 959 Charger?
http://www2.towerhobbies.com/cgi-bin...&I=LXAVN1&P=ML
J Smith is offline
Old 07-27-2004, 03:48 PM
compaq888's Avatar
http://www2.towerhobbies.com/cgi-bin...?&I=LXL353&P=M
that charger, I use it and it works great
compaq888 is offline
Old 07-27-2004, 03:49 PM
Aww I saw that too. How long does it take to charge?
J Smith is offline
Old 07-27-2004, 03:52 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Default Re: Questions on getting a Starter Box
use this one
Part Number: OFN10224
Product Name: 12V Battery Charger, 110AC
Price: $11.95
Marcos.J is offline
Old 07-27-2004, 03:55 PM
Default Re: Re: Questions on getting a Starter Box
Originally posted by Marcos.S710
use this one
Price: $11.95
Now I have a question for you. Whats so much better about that one compared to the first one? And finally where I can buy that one?
J Smith is offline
Old 07-27-2004, 03:56 PM
compaq888's Avatar
I also have the superbrain 959 charger, but I use it for charging my receiver pack. The problem with the superbrain charger is that it will charge up your bettery but it won't give you as many mah as the $11 charger, if you want to be more accurate you need to buy a $100+ charger.
the more mah you got the more the battery works, and the super brain got .5, 1.0, 1.5, 2.0, 2.5, and etc, while the battery is like 600mah, so the superbrain can only get .5 which is 500mah to your battery, which means less run time, but the advantage is it will charge it full, with the $11 charger you never know if it's full or not.
this is kinda of confusing, sorry
Old 07-27-2004, 04:06 PM
Alright, I think for now I will stick with the $11 charger. Thanks for the info.
J Smith is offline
Old 07-27-2004, 04:37 PM
compaq888's Avatar
also the super brain 959 can't charge those kind of batteries, so you can't buy it, the $11 charger is your best bet.
Old 07-27-2004, 05:35 PM
Alright, well I just purchased the Ofna Starter Box and Hobbico Charger.
I just got back into Nitro after a 2 year break and this is the first time I am using a non-pull start motor.
J Smith is offline
Old 07-28-2004, 12:12 PM
Can you overcharge the batteries with the overnight charger? How do I know when to charge my batts and how long to charge them, is it ok if I over charge them?
J Smith is offline
Old 07-28-2004, 12:21 PM
PSI Racing's Avatar
You could use the Super Brain 959 to charge a 12V battery.
Here's a quote from the Tower Hobbies description.
"Charges NiCd & NiMH batteries, Lithium, and Lead Acid"
PSI Racing is offline
Old 07-28-2004, 02:49 PM
compaq888's Avatar
PSI read the super brain instruction manual, it states it and i quote "DO NOT attempt to charge Alkaline, Dry Cells, Gel Cells, Lead Acid, Lithium, or other batteries with this charger."
The only betteries this charger charges is nickel cadmium or nickel metal hydrate batteries.
Tower hobbies makes mistakes too, but before i tried to charge the batteries i read the instructions, I don't need to have any accidents from exploding or leaking batteries.
Now, would you like me to also scan the instruction manual?
Old 07-28-2004, 03:05 PM
PSI Racing's Avatar
My bad Compaq888.
It's the wrong model number.
I was talking about the 969.
Old 07-28-2004, 03:21 PM
compaq888's Avatar
damn, i should of gotten the super brain 969, that way my charging would be really accurate, but i'm on a budget
Old 07-28-2004, 03:26 PM
PSI Racing's Avatar
It's not that much more than a 959.
It's less than $100.
