Old 07-08-2004, 10:50 PM   #1
Taylor-Racing's Avatar
Default Receiver Pack Charging / Discharging
Hi guys,
We have a five cell AAA 850 mAh (NiMH) receiver pack that's playing up.
It's a near new pack and is normally charged with a 50 mAh wall charger, left overnight.
At our last meeting it went for a couple of minutes and died. A fellow racer decided it was just being recalcitrant and gave it a short 5A belt around the chops. He then charged it normally and it was fine for the rest of the day.
I'm thinking that maybe it needs cycling a couple of times to condition it, but I'm not really sure.
What I know about batteries could be chiseled on the back of an asprin with a crow bar, so any advice on proper care and feeding of this pack would be welcome.
We'll be using a Supanova 250S to charge/discharge it.
Many thanks for any advice.
Taylor-Racing is offline   Reply With Quote
Old 07-08-2004, 11:07 PM   #2
rjl's Avatar
Gav, charge at .8 amp, do not cycle too often, it's not required. When you get the charger let it go through a discharge and charge cycle. Write the result and date on the pack. Do this every few months to compare.
You should get 2-3 years out of a good pack.
rjl is offline   Reply With Quote
Old 07-09-2004, 06:41 PM   #3
Default Charging with harness switch "on"
Can you damage the receiver if you accidently attach your charger while the harness switch is set to "on"? I have a dead receiver and am checking everything.
Phildo is offline   Reply With Quote
Old 07-19-2004, 05:42 PM   #4
Neil's Avatar
Send a message via MSN to Neil
I dont know about your switch by my harness disconnects the charging tail when the power is switched on. You can check yours with a voltmeter. Just test the charging tail with the power switch on and you should have 0 volts. Hope this helps
Neil is offline   Reply With Quote
Battery Charging/Discharging bootnylee Rookie Zone 5 12-27-2006 09:54 AM
About Charging and Discharging rates ... Tabushi Electric Off-Road 3 07-17-2006 06:17 PM
Charging and Discharging inet-projects Rookie Zone 3 12-10-2005 07:27 AM
receiver pack charging RebelRacer Electric Off-Road 6 08-07-2004 04:47 PM
Charging/Discharging techniques? TC3Racer67 Electric On-Road 10 04-18-2004 06:03 PM
SEO by vBSEO 3.5.0
