NTC# Upgrades
NTC# Upgrades
im not sure if there is a post for this yet.
But i have $170 to spend on upgrades for my NTC3 have any suggestions??
My car is all stock and i just broke the engine in.
iwould like a little more power and alot more control!!
can you suggest any products that have worked well in your NTC3
(1) V2 rear suspension upgrade....aorund $35
(2) 21 and 27 pinion gear $5 and $5, then reuse the stock 54T spur and get a 48T 2nd spur for 2nd speed...$5
(3) Lightwegiht clutch housing....around $12
(4) The FIX for the front gear box $15, and since you will use the V2 rear suspenion, no FIX need to be install at the back.
(5) If you want some high RPM clutch engagment, get a 3 shoes flywheel and 2 package of clutch (2 on each package, and you will need 3) and 2 package of copper springs ( again, 2 on each package and you will need 3).....this will give you a higher rpm clutch engagment and your clutch will be punchy, not everyone like it but I use it on the large track.
(6) AE Spring sets...it is a must ($30)
(7) front blade sway bar set ($35)
(8) rear wire sway bar set ($25)
(9) Woven carbon upper deck for LOOKS....not really performance upgrade, but just looks better)
(10) 3racing side carbon brace, I think it is a must to protect your tank...
(11) Dual chambered pipe from AE or RDLogics Turbo 2 pipe for NTC3.
(12) RPM bumper, that is the FIRST THING you should get....so put that back to #1 on the your list.
(13) Yellow color diff gear and pinion gear.....heavy duty material.
I think these options will easily erase your $170.....but that is all your NTC3 will be needed....NTC3 can be race with stock equipment, these parts will make your car last longer.........but not forever.
Registered User
BMI Chassis
Originally posted by 20 SMOKE
i saw that ofna as a 0.8 module for ld3 and tc3 if you spend money on a 2/spd look at it
Just to make sure NTC3 is already a 0.8 module gearing....no need to upgrade to mugen or other 0.8 module gear box.
Unless, you are talking about Hongnor/OFNA centax with 28/29T 2nd speed pinion.....that I think it is a waste.
so will that bmi chassis help my handling?
because right now it sometimes looses controle in the corner or when i excelerate.
what can fix that?
what can fix that?
For free hopups, why not go to AE's website and download one or two of the pro's setups for your car (version 1 or 2?). Do this setup exactly, and find the one that works best on your particular racing surface.
Then learn to drive the car a lot before wrenching on it any further. Once you have done this, you will know if a hop up has been worth the effort or not. Hopups can't mask poor setup or average driving.
Cheers,
Mike.
Cheers,
Mike.
what can fix that?
what can fix that?
ok im going to go to the Ae web site and download the set ups.
what about like tuned pipes? can you suggest any?
should i get one?
what else should i get?
my car is all stock!!
i want a couple of good parts on it.
Right now i have a 1 speed. is it hard to change it to a 2 speed?
should i get one?
OK, so you must have one of the earlier models with the single speed. If you want to see some real improvement in your speed, then go out and get the 2 speed for sure.
If you're using the factory pipe, it will be fine for now. You'll really notice the difference with the 2 speed
should i get one?
should i get one?
Hey,
im Richy89 for some reason they wouldent let me post so i made a new account.
if you notice my last number on my screen name was 89. That is when i was born. my nuber now is 15. my current age.
i havent been able to post in a while so i have a few questions.
is it hard to change frome a one speed to a 2 speed??
yes it is an RTR
and how do you tweak the chassis?
i have to go check if it has oil in the shock i havent even looked yet.
And does anybody know where i can get a cheap 2 speed.
i found one for $41 on ebay and it was assembled.
yes it is an RTR
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
I agree with what the guy said that had that long list of stuff, except stick with the 2-shoe clutch. I have not tried the 3 shoe, but I know the factory guys run the stock 2 shoe. Depending on the size and grip of your track, you may eventually want a one-way front diff, but don't get it until you can drive without hitting stuff. The gear is not forgiving when you hit stuff on-power.
Definitely get the 2-speed
