Old 10-16-2010, 03:26 PM   #16
td-civ's Avatar
Trader Rating: 18 (95%+)
Originally Posted by RB|PoweredShimo View Post
RB engines are made by Novarossi to RB specs so both are reliable and powerful engines.
If you have a RB engine, on the carb rubber bellow (the black one) you can see the letters (NOVA) that means Novarossi and RB engines are made in Italy too.
You can see it in the pictures
yes they are made novarossi but i have ran both and rb have always last longer then any of my rossi and cost less
td-civ is offline   Reply With Quote
Old 10-16-2010, 10:32 PM   #17
I would definitely go for RB.
The 353 has better top end compared to the Flash 12 but less bottom than the Flash, so basically they traded each others bottom and top ends.
RB engines are made in the same place as Novarossi, only they are made to RB specs so in my eyes they might be slightly more aggressive in terms of port timing.
Since I changed to RB, I don't think I will ever change to anything else, ever. They run as cool as ice, provide HEAAAAAPS of power and will last nearly forever!
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
SEO by vBSEO 3.5.0
