Xray RX8 1/8th Scale
#931
#935
The way your spelling I think you might of had to many red cups See you at the Motonica race
#939
Hi guys,
Recently brought an rx8 and just completed the build with a novarossi kangaroo motor. Just a quick question as I've been reading alot about problems xray has with the clutches? While running my motor in still the clutch is barley engaging at all at half throttle? I tried tightening and loosening still no go. Shimmed to .07 clearance. What could be the problem? And how do I fix it?
Thanks in advance
Dave
Thanks in advance
Dave
#940
Hi guys,
Thanks in advance
Dave
Thanks in advance
Dave
==> loosen the spring nut
==> move the bell closer to the clutch shoe with the shims
==> change to a softer spring
-X-
#941
How to make rear end really stable ( really planted to ground ) ?
I feel my car is a bit twitchy when off throttle.
Can you rx8 guys give me tips ?
#942
My for sale thread
if any of you are interested
http://www.rctech.net/forum/r-c-item...l#post10506896
#943
Hi guys,
Thanks in advance
Dave
Thanks in advance
Dave
Hope this helps ya
#945
Can you guys check my setup ?
( problem : a bit twitchy at rear end )
