Xray RX8 1/8th Scale
#1096
If they were for me I would be so happy. Sadly for my kids though I get one for myself and I get to choose which one it is haha. Cheaper than go karting which they have recently got out of (thankfully).
#1097
cheers.
#1098
Unfortunately had a lot of problems running the sons RX8 and he went through 2 clutches over two days. Clearly must be doing something wrong. But ended up changing out to the mugen clutch in the hopes this fixes things after a bit of research. Have not run the second RX8 yet as have decided it will be a spare car so am not sure if it was an anomaly with just the one car.
#1099
#1101
#1102
If you follow the steps on the clutch shoe card set small gap with spring tension nut flush with flywheel nut shoe will blacken nicely then you can set wider gap and crank on the spring tension
#1103
#1105
#1106
#1108
Put the new clutch shoe in an oven and bake it for 20minutes in 200 degrees.
The yellow clutch shoe from the xray nt1 lasted me a very long time with awsome cluth. very consistant and fast accelerating. Consistant because the clutchgap stays the same without much wear. No need for any run in whatsoever.
now i have the Serpent 977, been doing first what the guys told me and had problems. changed to my baking method and lost the clutch problems. All smiles again.
Worth a try and keep it secret so you gain an advantage
i use hard springs though
have fun.
