RCAmerica/Xray,Hudy
#481
I would recommend the Xceed Lipo (2s 1300mah).
The primary challenge I've found with Lipo's and the NT1/RX8 (they share the same batter plate), is when you move to Lipo, you typically use the XRAY Brass Battery Tray to compensate and lower the CG, which has dimension limitations in width and length (it's milled to about 82mm length and 29.5mm width (height dependent on how low you want the tank to fit). The standard composite is produced with nimh battery in mind, and has curves molded in to capture those batteries, or the other option is the graphite/carbon flat tray, which opens up battery dimension options a few mm's in each direction, but you lose the weight of brass.
Now, the older Xceed packs are about 82mm length, 29mm width and 10.5mm high and "dropped right in" the brass tray, the newer packs are the same width and height, but gained about 5mm in length..
** all measurements are from memory
I had to open the newer xceed pack, and rewire the balancing plug, which reduced the length about 4mm and allowed me to use the XRAY brass battery tray.
After thinking about all the work, I'm now asking myself if this is really necessary!
#482
#483
if not able to find that particular lipo pack
i believe that a 3+2 flat AAA 11OOmah nihm pack will work
these should have 89 31 9 dimensions!
#484
I THOUGHT OF THAT AS WELL, BUT I HAVE 4 OF THE KO RSX SERVO'S AND THERE RATED AT 7.4... come on xray get these packs in for us, or im suing for false advertising..haha..nah id NEVER hurt a company that can produce something so FINE, im in love with my kit, and i haven't run her yet..but im stocked up..4 bodies, about40 complete sets of tires, case of tornado competition 25%, JP Eagle 9< WICH I NEED A REPLACEMENT ROD AND PIN IF ANYONE HAS ! FOR SALE, THE EAGLE 9RS>, and a NOVA PTS coming<possibly>, but no damm LIPO...LOLOLLLL
#485
#487
#489
Not speaking for Drew, just giving my results.
#490
Thanks Drew
#491
The tires are good. Ralph has been happy with them. SRC is a company that has been in Italy for sometime now, but is just now opening up to the globe market. I think there will be a lot more from this company. They are the one's that designed the Kruzer 200mm gas body. So it is not just a tire company.
Thanks Drew
Thanks Drew
#492
Thanks Drew
#493
Maybe you can set a 3÷3 aaa that will give you 7.2v! Of course the performance of nihm. Vs lipo is no match but at least is a 1100mah enough for 45 minutes mains!
there used to be a guy who wired em up years ago, pretty darn sweet, light, packed a decent punch, but in my case id need 1 more aaa and im not sure if that would push the envelope a little to much in my case as i need 7.4 volts for my servos to perform as they ere designed to.
