driving with oneway
driving with oneway
hi guys,
I just install back my oneway unit in my car, and plan to using it.. Before I hit the track, I would like to hear and learn fom you guys about driving with oneway, is it realy true we can't use brakes? because I've seen some racer out there using oneway in a small technical track. So any input, tip and tricks will be much appreciated..
Super Moderator
Re: driving with oneway
Originally posted by goodspeed
hi guys,
hi guys,
which way?
If your not useto a one way the best way to learn is to practice (by your self) with out useing brakes at all! Not only will this help you get useto the one way it will also make you a better driver! I'm sure some one will disagree with this method but I have proved it works many times even with cars that don't have oneways in them.Good luck and I hope this helps you!
Re: which way?
If you do use brakes, it is easiest to do so when you are going in a straight line. You have a less chance of problems.
I set the brakes light and add a bit more toe-in for the rear (and maybe softer springs.) With a one way, I have much more steering anyways so I just basically coast through the turns and use the throttle.
Registered User
Using a bit of drag brake will help too.
If you have an EPA adujustment on your radio use it so that when you are on full brakes on the transmitter it is just enough to slow down the car and not make it spin out.
Re: Re: which way?
Originally posted by Palmaris Europe
I totally agree. One way requires a different style of driving that involves little or less brakes. Also more aggressive style. Not really suited to twisty tracks although it can work if the car is set up properly.
