Old 08-16-2010, 12:53 PM   #16
Send a message via MSN to PMSorber
Or get a LiPo or liFe...
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
PMSorber is offline   Reply With Quote
Old 08-16-2010, 04:57 PM   #17
yes, get a lipo or life. A good charge for lipo/life is only $40
silverM3 is offline   Reply With Quote
Old 08-17-2010, 12:56 AM   #18
blis's Avatar
Default Yep.. do what he said!
Originally Posted by nitrodude View Post
Just get a new one, they do need to be replaced once in a while. I try to get a new one every year, they are cheap compared to the cost of fixing a runaway car and blown $600 motor. I charge mine at .5A, otherwise you just hurt the pack, unless I need to charge at the track and Im in a hurry, then maybe 1.0A. Get a good charger, thats a must.
I'd say you've dropped a cell.. to check you have to unpack/unwrap the battery, use a simple multimeter to check across each cell's + and - and if one is considerably lower, you've found the problem.
Max Voltage in a NiMh cell, is relative to it's current (amp) capacity. If all the batteries are of equal voltage, and for each cell < 1.3ish Volts then you need to revise your charging method as the battery is still flat.
Alternately you could have a short in your wiring that's drawing current and likely to let the "smoke escape" checkout the insulation...
Final note, it's a lot easier to "spell it out than it is to do.. nitrodude's option is good advice.
Runaway's are evil!
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
SEO by vBSEO 3.5.0
