Old 08-14-2010, 11:37 AM   #1
Exclamation fuel tank problems
hey if anyone can help me on this please do i just bought a new hpi rs4 evo
and it bogs on the turns when i push the accelerator never had this problem on eny of my other nitro cars?
jdm_rs4 is offline   Reply With Quote
Old 10-23-2010, 11:58 AM   #2
gt fast's Avatar
had the same issue. put both your needles all the way in, then with your highspeed turn it 3 times out and same with low speed, try it, then readjust them as you go. forsome reason these rs4's do that even if there is still fuel in motor. mine did forawhile and i would have to go chase it down, if that doesnt help try to add some extra inches on to your fuel line. if that doesnt work, id check and see if your carb may be moving on you or your idle is to low. hope it works man
gt fast is offline   Reply With Quote
Old 10-23-2010, 03:43 PM   #3
Geezatec's Avatar
Question to ask. Does it happen all the time? Have air bubbles in the Fuel hose between the tank and carb? Is the tank full or below half full?
Geezatec is offline   Reply With Quote
Old 10-23-2010, 04:15 PM   #4
My RS4's problems all came down to a bad tank seal, now I have the joy of re-tuning the engine. But mine is also old school original RS4 Racer.
There is a reason I replaced my original fuel tank with a Serpent tank besides it being larger, it got rid of the leak prone fuel primer.
FoxRob is offline   Reply With Quote
Mbx6 Fuel Tank pl_unc86 Nitro Off-Road 33 08-04-2009 05:43 PM
Losi 8ight fuel tank splitting at the seam LVBaja Nitro Off-Road 35 09-13-2008 09:51 AM
Pressure inside fuel tank... Raycer Nitro On-Road 10 06-10-2004 01:25 AM
SEO by vBSEO 3.5.0
