Old 08-05-2010, 10:03 PM   #1
FaanP's Avatar
Default Underdrive and Overdrive
Hi all ....
Another newbie question from my side.
I can't get my mind around the underdrive and overdrive concept - the one you pull with your fron wheels and the other you push with your rear wheels, but which one is which?
Which one is good and which one bad?
How much of which do I want since it make sence that much of one can't be good?
What effects do they have on the handling of car?
Thanks again for your help !!
Faan Pretorius
FaanP is offline   Reply With Quote
Old 08-06-2010, 12:53 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
Overdrive = pulling on the frontwheels, giving more on power steer but due friction also eating power and speed
Neutral = giving the best predictable and lineair driving car.
Underdrive = driving like rear wheels but when those wheels will slip the front will ad making it 4wd. It will give a loose end but because no friction the best topspeeds.
It is not which is the best, it is just which is needed on the track you drive.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 08-06-2010, 02:23 AM   #3
QuiXoTic_NL's Avatar
It depends on your drivetrain. Roelof drives 8th scale, which has a one-way on the front axle. In 10th scale there typically is a diff or spool in the front axle, which makes a difference here.
On a 10th scale, overdrive will give more steering off-power, entering a turn, and less steering on-power, exiting a turn. Underdrive will do the opposite.
When having a front diff or spool, overdrive and underdrive will always make your drivetrain inefficient. A front oneway solves this for underdrive, but makes you loose braking on the front wheels.
Shepherd V10 Pro 2015 - Matrix tires - Novarossi Engines - Runnertime
QuiXoTic_NL is offline   Reply With Quote
Old 08-06-2010, 04:54 AM   #4
asw7576's Avatar
My 1/8 = I wish I could go under drive even more. At the moment ....., I only get 2 - 3 pct underdrive max.
My 1/10 cars = I like driving underdrive definetely .... some car get 5pct, some 10pct underdrive. I feel more driveable consistency with that setup.
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
LOSI XXX-S, Tips and Tricks, Open Mod, etc John Stranahan Electric On-Road 1027 08-30-2016 07:41 AM
Why use overdrive with split? Fabian K Nitro On-Road 30 02-22-2007 07:16 PM
SEO by vBSEO 3.5.0
