**** Serpent Impulse Thread ****
#31
FactoryTeamTC3, that's a bunch of crap!!! For one the ball diff makes the car lighter. Second the ball diff is a lot less trouble to adjust. If you want to adjust the gear diff you have to take it all the way out of the car and then take it all the way apart.
If you want to make comments about the car you drive that's cool, but at least know what you're talking about..........
#32
If you're just going to be running on a local medium sized track then stick witht he stock diff. I had the ball diff for my Impulse but never put it on because it was never necessary and I saved it for the big tracks. Plus It adds unneccessary weight.
#33
Teach is always hardcore ... He races like that too.
"AND" Garett Giles (FactoryteamTc3) Doesn't even own a Impulse Pro so disregarde his comments. "AND" he hasn't finished a race ever I give him slack cuz he's only 12.
#34
heh.. ball diff will be the best hopup you'll get for impulse. if you want more turns loosen it, if you want more stable rear tighten it. easy as that.
#35
FactoryTeamTc3-
How the heck do you have a Impulse pro and why would anyone let you drive that car on their track? You can't even install Double Sided Servo Tape let alone be in control of a 50mph RC Car.
I hope you are not racing it at BB this summer.... First I have to put up with Milano in Stock TC... Now I will have to put up with you. What channel are you on so that I can buy the same frequency so that I am not in the same race as you?
Mike Webb
Mike Webb
#38
I am using the stock Spurs and Pinions that cam with the car.
#39
hi guys
what's the rate for the yellow impulse spring??is it 1.6 or 1.7
TIA
TIA
#40
SER 909414 Orange 1.4 mm / 22.7 mm / 27.0 mm
SER 909415 White 1.5 mm / 22.7 mm / 27.0 mm
SER 909416 Yellow 1.6 mm / 22.7 mm / 27.0 mm
SER 909417 Red 1.7 mm / 22.7 mm / 27.0 mm
SER 909418 Blue 1.8 mm / 22.7 mm / 27.0 mm
