Kyosho V-One RR Evo or FW-05R?
Which one of these is better?
umm i kinda run on parking lots and places with smooth asphalt.
also, the 05R can use the STS RS3 engine with a SG crankshaft right? I ask this because I have this engine laying around in its original packaging since november and I wanna put this engine to use.
give the FW05R a try you wont be dissapointed also Kyosho has a new on road weapon comming out the Triple R
wait i also have another question that no one is answering. Will the HPI R40 would with an SG crankshaft engine?
Also, which is easier to build, FW-05R or R40?
evo for sale
FOR SALE
Kyosho 1/10 V-One-RR Evolution. This is the genuine kit. not the upgrade kit.
Brand new, never ran. this is an exspensive car to replace..
.im selling as im desperate for cash....
Gen Kyosho graphite radio tray #vzw051.
kawaharra active diff
'5 star' rear alu. camber link set
Gen Kyosho front and rear titanium layshafts. #vz025 & #vz026
one-way gear 18tooth for front layshaft..very unique..excellant roll-in to corners
Gen Kyosho brake holder.
Alumin. gear holder.
'K Factory" brake disc.
'3 Racing' chassis with graphite battery holder.
'3 Racing' left chassis stiferner.
'3 Racing' right chassis stiferner.
light weight 750 nmh battery pack.
Gen Team kyosho alumin gears. 25.26.....
18 tooth titanium gear
'Shimo' front one way and out drives..
'Kawaharra' 1st gear carrier.
'K Factory' carbon rear top brace.
titanium front one way gear.Gen Kyosho alumin. drive hex's
"3 Racing' .2 roll plate.
K Factory front hinge pin holder.
Kawaharra graphite front shock tower.
Kawaharra graphite rear shock tower. plus varius different graphite rear towers
Alumin. rear 'GT' mount.
alumin.rear 'GT' shock tower
All Titanium screws and purplu alumin washers.
brand new..ready to paint porche gti body.
and all manuals, original parts, etc..
Novarossi 'JP S1'......as new, very fast....
** no servos are in the car...and light blue front springs******or graphite servo protector.
$800.00 AUS.....plus frieght......
mike
mike
New Kyosho V-one-RR Evolution parts
FOE SALE
KYOSHO V-One-RR Evolution spares and upgrades.
2 x Gen Kyosho alumin. difs. complete 1 with k factory hard blue gear.....$ 70.00
1 x Gen Kyosho LSD diff complete..........$100.00
1 x Gen Kyosho adjustable slipper diff complete .....$70.00
1 x Gen Kyosho front one ways new...$15.00
1 x go fast gear kit never used, in packets...complete (15 toth spur49 tooh pinnion, 66t rear belt,
side belt,2 x 24 tooth pulleys....$70.00
Gen Shimo front one way plus out drives and titanium gear...$70.00
Team Kyosho '26' tooth front pulley...2.5 split..$20
Complete gear box, including Gen kyosho titanium lay shaft,
titanium 19 tooth gear.
alu gear holder.
titanium brake holder.
K Factory brake disc.
gears, one way, second gear box..$120.
Gen Kyosho parts.. still in gen kyosho packaging..
part numbers are:
2 x vz 106 front swing shaft $$10.00 each
1 vzw013 middle belt 378 t...$10.00
1 x vzw 020-1 diff caser seals.pkt 4..$$6.00
1 x vz015 diff joint..$8.002 x vz098 rear body post..$4.00 each.
set titanium rear dog bones..for v-one-r $20.00
1 x vz113-61 fispur gear..$8.00
3 x vz113-60 first spur gear..$8.00 each.
1 x vz114-55 2nd spur gear...$ 10.00
1 x vz114-56 2nd spur gear...$10.00.
1 x vz004 rear susp arm set...$10.00
1 x vz101 front susp. arm set...$10.00
1 x vz009 diff gear set..( no main diff gear)...$10.00
1 x vz103 small parts set..$6.00
1 x vz102 servo saver holder....$7.00
1 x vzw050 SP main chassis new.....$60.00.
9:12 PM 5/31/04
mike...allprices are in aus dollars
alu gear holder.
part numbers are:
9:12 PM 5/31/04
