Ntc3 diff setup
Ntc3 diff setup
Can someone please explain how the diff works in an ntc3??? For racing how should I set it up ( 1 way, locked etc.) does it actually displace different power to all 4 wheels..?? How does the one way work.. What is better.. Thanks
Thanks for the info... Is the diff-diff the stock and did you use the steel diff gears... I'm putting a max xxl3 .12 in it and have head the diffs have alot of problems.. Just trying to find out the best way to set it up..
what exactly am i looking for in steel diffs.... the pions only or do i need the complete diff assembly or both.. not rally sure.. do you know of a link that would discribe what i need or even show.. thanks for the help man
http://www.rctech.net/forum/nitro-ro...-rc10ntc3.html
check in there.
youll be mostly on your own finding the diffs.
youll need every piece. When i priced it out it was about $60 to build one diff with bearings (inner diam of ld3 bearings isnt the same)
check in there.
