Old 05-21-2004, 03:57 PM   #1
stormperson's Avatar
Send a message via AIM to stormperson
Default Lube for thrust bearing in centax III clutch?
Hi, I was wondering what i should use for the lube in the thrusbearing of my centax III clutch and where to buy it. Thanks!
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 05-21-2004, 04:54 PM   #2
Solara's Avatar
Trader Rating: 16 (100%+)
Assoicated black grease..........probably at least 1 time per race day....some ppl might go for regrease per HEAT, but they usually clean the bearing up and regrease, not re-apply over with exisitng grease, that will be too much
Associated Stealth Black Grease
wanted. Slapmaster thrust bearing or Axiom thrust bearing... Tron 101 R/C Items: Wanted to Buy 1 03-24-2008 09:34 PM
Thrust bearing 20 SMOKE R/C Items: Wanted to Buy 1 10-28-2007 06:02 AM
Quick Can a ceramic Thrust bearing be used in a centax 2 TRFTIM Nitro On-Road 1 04-19-2006 10:56 AM
Removing a stuck thrust bearing from the clutch bell Darthswan Nitro On-Road 0 08-01-2005 10:13 AM
Lube me up. Diffs and Thrust washers!! rayhuang Electric On-Road 8 02-22-2005 12:08 PM
SEO by vBSEO 3.5.0
