Old 12-21-2014, 02:35 PM   #286
MikaR's Avatar
As for rubber tire options I noticed Kyosho DRX wheels are 12mm hex and the axle is 6mm, correct, so basically these would fit FW04 paired with 12mm traxxas 12mm wheel hexes for 6mm axle. Not optimal but for parking lot racing would propably do. There was also information that proline 2.2 road rage tyres would fit kyosho DRX wheels..
MikaR is offline   Reply With Quote
Old 12-21-2014, 08:33 PM   #287
Ed Anderson's Avatar
Trader Rating: 26 (100%+)
The TR series buggies and cars used the same wheels as the super ten, and tires are the same as the super & fw-04.
The D platform cars, not sure what the axles, hexs, and wheels are like... but the tires are the same as the old Landmax & landmax II. This tire is a lot bigger. You can almost fit the super tire inside it. I'll try to get a picture.
Liberty Raceway @ Wagner Park
Ed Anderson is offline   Reply With Quote
Old 12-21-2014, 10:39 PM   #288
MikaR's Avatar
Ok, prolly too big then. And super needs slicks or foams. I'm in the process of getting some hpi super rims and tires, also will try those traxxas hexes to fit the hpi wheels. My car does have those custom cut 12mm hexes but they're a bit worn out on the edges (at least one of them).
Old 12-23-2014, 11:21 AM   #289
MikaR's Avatar
Ok, I bought a set of HPI wheels and tires for this car from eBay. Have 12mm hexes.
Have changed gears and clutcbell to new ones from eBay as well. 13/17 and 43/39 gearing. This came with huge 16/19 gearing on the bell.
Foams still pictured.
Kyosho SuperTen FW-04-20141223_205616_resized.jpg   Kyosho SuperTen FW-04-20141223_205711_resized.jpg   Kyosho SuperTen FW-04-20141223_205512_resized.jpg
http://modelcartuning.simplesite.com/
Old 12-30-2014, 11:11 PM   #290
MikaR's Avatar
Hi guys,
I may be getting the 39666S older 2-speed for my fw04 but I believe the center shaft is too long. Do you know if I can replace it with the shaft of fzw56 to make it fit ? Other options ?
(If I get it and does not fit I'm willing to sell or trade)
Old 12-31-2014, 02:13 PM   #291
I can't remember, Mika; I will check to see if it will work when I get home.
I just found a new FW04 2-speed trans shaft the other day in one of my parts boxes.
Happy New Year! Jon
gamma13r is offline   Reply With Quote
Old 12-31-2014, 04:18 PM   #292
Trader Rating: 15 (100%+)
Not sure if it will fit, i think that's the older fw03 tranny (confirm??)... There were 3 types for the 04. 2 from Kyosho (1 basic black coloured, and the other better built fzw56), and another made by form racing. Good luck finding a form tranny, but there are fzw56 trannys around still. Avoid the black version.
nitro dave is offline   Reply With Quote
Old 12-31-2014, 11:45 PM   #293
MikaR's Avatar
Ok thanks.
Happy New Year too!
Old 01-01-2015, 08:05 AM   #294
banana rt's Avatar
im so glad to know that im not alone that still loving this beautiful car that ever made.
since im a 80-90's kid, so its impossible for not enjoying superten series era.
my fw03 still in a good shape, and its all stock. planning to get it 4 strokes, but i have no idea how to build it (what parts do i need for complete that project) and i think its a rare items now. keep this thread alive guys.
No guts No glory
banana rt is offline   Reply With Quote
Old 01-01-2015, 08:44 AM   #295
MikaR's Avatar
Glad you like it and you are not alone! Something special definitely about this car, the design, size and scale looks. Modern tourers are not quite like and the robustness of the shaft drive is a big plus. Wide selection of options available still around, too.
Old 01-01-2015, 06:20 PM   #296
banana rt's Avatar
i need advice for choosing optional tires for my fw03, the original one had cracks everywhere, i want it to looks and drive like a touring car, rubber or foam would be great.
thx guys
Old 01-01-2015, 08:04 PM   #297
MikaR's Avatar
Hpi super nitro tires or kyosho fw03 tires. These can be fpund on eBay for instance.
Jon, did you have a chance to check the fw03 2-speed (green and yellow stock gears) fitting on fw04 or it's 2-speed shaft. Thanks again.
Old 01-04-2015, 12:57 AM   #298
MikaR's Avatar
Well decided to let the 2-speed go.
Those traxxas 12mm wheel hexes are a perfect fit for the fw04. Will post pics later.
Old 01-04-2015, 05:39 AM   #299
MikaR's Avatar
If anyone is in need of engine mounts have a spare. Alternatively I'm interested in a rear exhaust header/manifold if anyone is willing to sell.
Old 01-05-2015, 07:44 AM   #300
banana rt's Avatar
asking superten's owner.
anyone knows the diameter and width of the original supertens wheel/tyres (fw03).
planing to get foam tyres set for my fw03, but i think 1/10 foam tyres set diameter too small for the superten. So is it posibble to mounted 1/10 wheels with 1/8 donuts foams?, since the diameter of un-trued donuts foam thick enough.
thx for advice guys
No guts No glory
where to play RC on road in Putrajaya shokyo Malaysian R/C Racers 4321 04-30-2011 12:02 PM
REBUILDING A KYOSHO FW04 SUPERTEN thx-n 11 Nitro On-Road 22 11-20-2010 07:18 AM
Superten ONLY!!! segaff Singapore R/C Racers 71 09-11-2005 07:26 AM
