Hey guys,
I just thought that no forum is complete without its own Ofna OB4 thread... I'll get us started here... How can I stop my car from spinning out when I accerate moderatly while turning? I'm running 10k silicon grease in the rear diff and HPI red prolinear springs. I was thinking about purchasing ball diffs and running them very loose. Would that work?? Here are some pictures of my car:
WeatherB check your rear toe in. The Ob4 manual says 2.5 to 3 degrees of rear toe.
You dont need a toe in gauge if you have camber gauge. Stand the OB4 on its tail then set the gauge for 2.5 degrees negative camber. Adjust your pivot balls to match the gauge. While you are at it drop the car on a counter or sumtin and set it up:
Neg 1 degree front camber
" 1.5 " rear "
That should get you started.
Yes the Ofna power clutch is very similar to a centax.
Any of you, using the Front One-way for the OB4??? Is there anything else I'll need to run this??? The Ofna WebSite just shows the One-Way, and nothing else.
Have you guys seen the Cross brace 'tween the upper deck & the rear bulkheads?
Weeee haw! just got a couple in the store, nice. does a lot for flex too.
Hey Everyone,
I got some more pictures of the car now... Foger, I got a serpent camber gauge a while ago, and the camper and toe should be setup correctly now. As for the porting, I don't recomment you try it, unless you don't mind purchasing a new engine incase you mess up the colt 12... Look below for more pictures of my car, my tool box, and the learjet I made in Grade 7 tech class... It got me a 90% in that class...
