Old 06-09-2010, 07:30 AM   #1
jameslow's Avatar
Default stabilizer bar question
Hi, Does anyone know what is the major effect if i remove my front stabilizer bar but mine rear stabilizer bar are still on.
Also what will happen if i remove both front n rear stabilizer bar? Thanks
jameslow is offline   Reply With Quote
Old 06-09-2010, 08:31 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
You will get more grip into the front but if you are using thick oil in the dampers then you also will create a slow reacting front because the more roll will use more traveling of the suspension.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Hot Bodies D8 Truggy Greg B Nitro Off-Road 9918 10-13-2016 02:54 AM
Droop-question Low_E Electric On-Road 15 10-22-2009 07:25 AM
SEO by vBSEO 3.5.0
