-   Nitro On-Road (https://www.rctech.net/forum/nitro-road-3/)
-   -   Need help tuning MT-12 (https://www.rctech.net/forum/nitro-road/40560-need-help-tuning-mt-12-a.html)
Drivrfound 05-14-2004 11:57 AM
Hey guys,
I've just intalled a new piston/sleeve in my MT-12 and I'm having trouble re-tuning. The main problem is I'm not very familiar with three needle carbs, I'm comfortable with the HS and LS needle, but the mid is screwing with me. Does anyone have the factory settings for this carb? or what are you running?
Thanks a lot guys,
Patrick
P.S- I've just started to lean it out from breaking it in, and I find it's bogging at a little over 3/4 throttle.
afm 05-14-2004 01:44 PM
Re: Need help tuning MT-12
Originally posted by Drivrfound
Hey guys,
Thanks a lot guys,
Patrick
HSN = 5 turns out, then start leaning 1/8th at a time if needed.
LSN = 3 turns out, then lean or open as needed to get at least 30 seconds idle without engine clogin to the point of dying, it should hesitate a little after 30 seconds but not die. To do this, let engine idle then press full throtle for a second or two to clean it out, then check the 30 seconds idle.
Mid Needle = flush with carb body with slot for screwdriver pointing the fuel inlet, then DON'T EVER TOUCH IT AGAIN.
AFM
Drivrfound 05-15-2004 01:07 PM
Thanks a lot, as it turns out I had my adjustments screwed up. I was using the mid as the low and vise-versa...
Thanks again,
Patrick
gioJahn 05-16-2004 09:53 PM
mt12
pwede malaman san ka nakabili ng parts for the mt12?
thanks
Drivrfound 05-17-2004 01:24 PM
Sorry man, I have know idea what you just said...
Patrick
