-   Nitro On-Road (https://www.rctech.net/forum/nitro-road-3/)
-   -   TIPS ON MTX4R SET UP (https://www.rctech.net/forum/nitro-road/404086-tips-mtx4r-set-up.html)
JDOM111 05-31-2010 07:07 PM
Just getting in to road racing and could use some help on the set up on a mtx4r like what fluid to use on the front and rear diffs,caster ,camber and any other that might help.I started to race at bluediamond in new castle delaware witch has a 140 ft straight away.I was told i do drive allittle aggresive and i would like to set my car to my driving style.I know there is somedody out there that drives the same way if not even more.I have a mtx4r with all the goodies,jp eagle 12 black version with a mega power pipe.any and all sugestions will be helpful.Im not new to rc just trying something different:cool:
lil-bump 05-31-2010 08:30 PM
I recommend starting with the stock setup. You can download it from the mugen seiki site. That setup is very good if your just starting out.
Francis M. 05-31-2010 09:32 PM
Track width = 199F / 200R
Use the stock shock oil 600 wt
Stock Springs
Roll Center no shims in the front upper arms
Rear Roll center lowest arm setting / 1mm shim on rear upright.
2.2 rear sway bar
Toe / 1 out F / 3 in R
Ackerman = A
Diff 50k f/r
Droop -1f /-3.5r
Ride height 5f 5.5r
Caster centered
That's the basic set up I run before making changes
