Kyosho Pureten Alpha 3 4WD
Hi
I have just recieved my first Nitrocar and it was great. I did like the movie said in drive in and so on.
Now I have a problem with the car. It has problems with breaking and when I put it on the floor, it breaks forwards. Then I checked both gears and they wasn´t running smooth. Then I took the engine out and ran it slowly with the fingers and it was hard on the gear. I have no idea what could be wrong. Now the gear on the engine is running smoothly again after I took the ring and lock of, but I am still a little concerned about what has been wrong or may still be wrong.
The first time I ran with the car where I should give full throttle the four screws which holds the engine flew of, but I mounted four new screws and ran again with out problems.
I hope that you can help me or say that it is ok to run again.
sound like your engine mount screws were loose! When it was loose, the engine will shift towards the main shaft when you try to pull the starter. That shift will cause a gap problem between the main bell gear (the one that attached to the motor) and the main gear on the center shaft. That reduction in gap will make the engine brake (more like not moving anywhere). What you can do is loosen the engine mount screws (not too loose...just enough that you can move the engine from side to side), take a piece of paper and slip it in between the bell gear and the center shaft gear. Slide the bell so it would slightly squeeze the paper in between the main gear on center shaft. Tightened the engine mount screws. Restart your car and see the difference.
HOpe that helps
HOpe that helps
Thanks for the help. It looks like it works ok now. Have you any idea how long the glowpipe works. ( how many times). I have only had this car for about a week and now the glowpipe doesn´t work anymore.
Is there anythink that I shall be careful about with my first nitrocar.
Super Moderator
hi
I mean the glowplug.
ok thanks.
Is it better to run on 25% nitro instead of 16% and does it give more topspeed.
If I forexamble run on a small area, can I then run the engine down at lower speed.
Re: Kyosho Pureten Alpha 3 4WD
Super Moderator
ok thanks.
ok thanks.
those GS15 dont make a lot of power anyway. Get full ball bearings first. if youre running in a small area, play with your trigger don't just punch it all the time. I think your glow plug ran out battery. The alkaline version doesn't last that long. Go to your local hobby shop and buy yourself the rechargeable ones. It doesn't cost a fortune yet you get the most out of your glowplug igniter.
I have a recharcebly glowplug. So what I mean must be the glowpipe or whatever the name must be. The one to make the spark in the engine..
What is the difference between the GS15 and the GX15 engine. Mine is a GX15 and you wrote GS15?
Is a speed of 60 to 65 km/h not good enough.
Is there any of you who have had problems where the fuel have difficults runing from the tank. I have little airboubbles in the fuel and sometimes when I break down the car just stops. I just replaced my glowpipe and the car is only about one week old...
When I got my car, there was a DVD with instructions for about 115 min. I followed then manual as said in the DVD. Everything was okay the first 4 or 5 times after that, but when the bolts from the engine went loose, all my small problems began. I have problems with starting the car, and it seems like it is the nitro from the tank which is the problem but Im not sure. Anyway the airboobles seems like the problem.
