Mugen MRX-4
#1456
Originally Posted by nigelnuggets
steering arm meaning the ackerman arm? what is this steering arm?! its driving me crazy. and how does it affect performance?
is the upright like the kyosho now? like 0 and 2 and 4 degrees? that kinda thing?
How high (or low) will affect the steering on the amount of steering throw vs. the shock travel (during the travel of the shock, the toe-in/out adjustment will vary). Bumpsteer is an adjustment commonly used on Off-Road cars and helps on bumpy tracks. Sometimes better to not mess with bumpsteer...
Other adjustment possible with those new uprights is the wheel offset. The handling is different if the wheel sits inner or outer on the upright. I can think about the difference in handling regarding the offset, but after the shock of hearing that hard chassis improved traction on loose tracks, better to try by myself what does the offset change.
#1458
So is that the suggested starting point with the new parts? (.5 spacer to outside and 1 mm shim under steering link)
#1460
Thx. so the new "standard" set up will be lowering the ball link height on the steering arm relative to the original parts. I wonder what effect that will have on bumpsteer and steering.
#1461
I tried to figure what's happening when you modify and lowering the position of the steering link connector you're modifying the toe-out ratio vs. the shock travel (I could be wrong... but what I visualized is a small decrease of the toe-out of that wheel. In few words, the most compressed is the shock, the more inwards turns the wheel). Don't expect a dramatic effect. On those machines a 1 degree difference is really huge.
Maybe those parts make the steering faster (and could be.. more delicate). Better to not adventure what will do those parts until assembled and track tested. Anyone has available at their LHS? Tested them?
#1462
bump steer.
#1463
which online shop does parts that can mail order to australia? mushroom has some parts but not the ones i want.
#1464
Berkley why don't you try Tracside R/c in Brisbane they always have Mrx 4 parts in stock, prices are very competitive with shopping OS. Drop Jeff an email I'm sure he will only to willing to help. Their web address is tracksiderc.net/main.htm. You'll find their email address at the bottom of the page.
#1465
I want to download the manual for this car.
Can anyone help?
I've checked www.mugenseiki.com, but can't find it.
Can anyone help?
#1467
Originally Posted by HarKonnenD
www.mugenracing.com Try there
In fact, i also want to see how is the installtion for the new upright and where are those shims(washers) to be placed.
#1468
Originally Posted by choisan
looked thru but no maunual online except setting sheets,....
http://www.mugenseiki.co.jp/mugen/mr...-e04kitstd.pdf
Paul
#1469
Originally Posted by chicky03
Here is the link to the new setup sheet with the new front uprights.
Paul
Paul
#1470
Originally Posted by iwk2much
Use attached to visualize Corse-R's explanation if it is still unclear
damn that short wheelbase business. HAHAHA
