Mugen MRX-4
#1396
Originally Posted by AKSHUN
Mike Strack, how are ya??
its me steve, i met you guys in cincinnati for the mid-west race.
never got a chance to say thanks for all your help, i left during the "A" main, had a long drive.
i see you and Ron did pretty well.
i have been working on the rear end of my car, and i have been trying different droop settings, never realized how important it was till i got home to my club track in hamilton.
ive managed to improve my personal best by 1.5 secs and made the"A" main the last 2 weekends.
thanks again, say "HI" to ron for me.
steve.
p.s. if you get time, check out our new sealed surface(ontario1/8onroadracingclub.com)
steve.
Good to read that all is going well with you. Hope to see you at the next one.
Take care,
#1397
HI
Hey ron! thanks, just gettin my car ready for the mid-west race in toledo this weekend, see ya's at the GLC.
#1399
Any gearing ideas for a track that has a 140' straight a couple of nice sweepers and some tight stuff?? More of a 1/10 track but some of us are trying to run these big cars here!! Pic.s of the track here...(click on the CAI link and then on track link) http://www.edmontonrc.com/Pages/default.htm
Thanks,
John
Thanks,
John
#1403
can you post you answer as i am curious as how to gain steering and the why part as well
thx
Lou
thx
Lou
#1404
Ultra hard clutch spring.
Seems that Mugen has launched a new and stiffer clutch spring along their 'old' hard clutch spring. Here's the info:
http://www.mugenseiki.com/h0774e.htm
Heard about it on the MTX4 thread and looked about it. Let's see if it's much stiffer than the old spring.
#1405
Originally Posted by HarKonnenD
You can drop down to the 16T for first gear for more pick up. The pics really don't show that much of the track though. Do you have any others?
Yes. Go to www.edmontonrc.com and go to the gallery link. You'll find pic.s of our indoor/winter facility as well as some more shots of the asphalt track.
John.
#1406
To lower the roll center= more traction
either lower the inner hingepin on the lower arm or
raise the upper arm inner hingepin.
Same rule applies to both ends of the car. It sounds weird but it's true.
So on the Mrx-4 put shims under the upper mount to lower the roll center and pick up some steering.
#1407
Thx
Will try it next race day
Lou
Lou
#1408
I took the MRX-4 out for its' maiden ride this weekend and couldn't get the car to shift into second? I had to loosen off the set screws that hold the balls so there was a little wigle of the shoes on the shaft (so the shoes wont rub on the bell housing...also had to sand the shoes a little as well), then I set the spring screws as per instructions and then proceeded to bak them out a 1/4 of a turn until they were almost backed all the way out....still only first gear?? Any ideas?
Thanks,
John
Thanks,
John
#1409
Thanks,
John
Thanks,
John
1.) Use silver or white paint to color the spring loaded screw head for one of the 2-speed clutch screws. (this will ensure you are making equal adjustments to each 2-speed screw)
2.) tighten the screws until they just fully collapse. Then turn each one out 2.5 turns...this will ensure the car is in first gear and difficult to get into 2nd.
3.) Set the spacing between the 2-speed clutch shoes and the 2nd gear bell by 0.5MM, using the center 2-speed clutch shoes set screws. Equal distance for each.
4.) Run the car under race conditions to adjust the engagment of the 2-speed. (Since we set the screws so tight, this will take a number of adjustments)
5.) loosen the two spring loaded clutch screws by 1/8 turn each time (one is now color silver or white for easy identification, even while the engine is idling) until the 2nd speed engages where you want on the track.
In the begining, be careful not to overrev the engine on a straight, since the 2-speed will be engaged in 1st gear. When you hear / see it not shift on the track, throttle back, bring it in and adjust the spring loaded screws.
