Mugen MRX-4
Old 12-16-2004, 05:58 AM
  #361
Suspended
Originally posted by Ed Delgado
Thanks. Didn't plan on buying the hatchback but now I'm very happy I did. Lots of cargo capacity.
I LIKE THE CAR ED,OH I THANKS FOR THE PICS OF YOUR MRX 4....CHOCO
SERPENTFREAK69 is offline
Old 12-17-2004, 10:17 AM
  #362
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally posted by SERPENTFREAK69
THANKS FOR THE GREAT PICS GUYS....THAT CAR IS AWESOME...I THINK I AM GONNA GET ME ONE FOR XMAS....IF U HAVE ANYMORE PICS,PLEASE POST THEM.........CHOCO
you might have to change your user name to "mugenfreak"
Marcos.J is offline
Old 12-17-2004, 11:24 AM
  #363
Suspended
HAHAHAHAHAHAHAHA
Old 12-26-2004, 06:54 PM
  #364
rcmike's Avatar
Trader Rating: 40 (100%+)
Default MRX4 Kits
Hi, Wheres a place that has MRX4 kits at a good price? A link or # please. Im just going to stick with another mugen. Thanks
rcmike is offline
Old 12-27-2004, 10:08 AM
  #365
choisan's Avatar
Mike,
if you can kindly solve my queries, that will be great!
i test run my mrx4 with 3 different brand of tyres, Jaco 35F/R shores and UFRA and CQ.
After mounted onto the rear axle with the quick release.
Jaco, the rear wheel has almost 3mm freeplay, noticeably, can use can to move it sideway from left to right.
UFRA, acceptable slight freeplay
CQ, no side freeplay
However, when i put all these tyres onto my Evolva, the Jaco's(had the problem pairs) freeplay can not be found on it.
Q1. Can you suggest how i can solve this on my mrx4?
Q2. What brand of tyres would be fit or officially certified by mugen for mrx4???
Really appreciate your advice as I just switched from Evova to MRX4.
choisan is offline
Old 12-27-2004, 10:10 AM
  #366
RE : MRX4
need some help, this beauty 's spinning out at corners when I hit the throttle. Have to go really slow, increasing rear camber don't seems to help,......
baldwinn is offline
Old 12-27-2004, 07:30 PM
  #367
MrChan's Avatar
Originally posted by baldwinn
RE : MRX4
higher up the wing + increase the rear toe in might help ..
Anyway, you got to check the track's traction too... If not that good, you may need to to loosen the clutch a bit .
MrChan is offline
Old 12-28-2004, 09:09 AM
  #368
I will try what you have suggested and thanks for the help !
baldwinn is offline
Old 12-28-2004, 09:13 AM
  #369
Ah10's Avatar
RE : MRX4
Check your drivetrain, I am referring to belts, make sure you are on 4wd instead of RWD.
What is your set up spec?
Ah10 is offline
Old 12-28-2004, 09:32 AM
  #370
I check it all, I think it could coming from the front too little down drop, could that be the cause ?
baldwinn is offline
Old 12-28-2004, 03:03 PM
  #371
Ah10's Avatar
That could be too, if the front end of the chassis grinding the asphalt then your rearend will be thrown around.
Ah10 is offline
Old 12-28-2004, 03:40 PM
  #372
ahh!! words of wisdom!!:-)
manokgt4 is offline
Old 12-28-2004, 03:50 PM
  #373
Ah10's Avatar
Hey Hey Hey, when are you going to Crystal Park again?
Ah10 is offline
Old 12-28-2004, 07:17 PM
  #374
Ed Delgado's Avatar
Default REX 321P Tuned?
Ah10, how do you like your REX 321P Tuned?
Ed Delgado is offline
Old 12-28-2004, 07:36 PM
  #375
Ah10's Avatar
Default Re: REX 321P Tuned?
I am still in the run in process now, when the motor is in operating temp, it still bind a little bit at the TDC so it still need more fuel!
But bottom end power is stronger then JP R1, that's the only thing I can see so far I will tell you more once it is fully broken in
So far I like this motor, and i hope it has the rpm range as the JP R1 then this is going to be a kick ass motor!
Ah10 is offline
