Ofna Cd-3
#871
Well ladies and gentleman, I believe that I have done the unthinkable.
The NTC3 clutch bell will fit perfectly on the force .12 shaft directly over the clutch. The only extra that I have to add is a bearing with flange on the end of the shaft to keep the bellhousing on. I'm going to be getting 20/26 for the clutchbell, and the 0.8 gearing is 55/49. My previous post stated that it was 54/49, but I was wrong, it's 55/49. 6 tooth difference, kinda odd.
Everything seems to mesh up fine and with the clutch bell being slighly larger actually in diameter, I think that my RPM's will be slightly higher when it engages.
Well, I'll post more later if anyone posts anything else cause it's time for bed. Yeah yeah, I'm a wus, it's been a long day!
#873
Originally Posted by trumpster1
master: are you saying that I would have to completely switch out the clutch from a 3 shoe clutch to a centax to get the gears to fit?
#874
au: I'm not saying that the OFNA gears will fit. When I was at my LHS last night I used the Team Associated (NTC3) gears on the NTC3 bell and it meshed with the 0.8 gears from OFNA with no problems. Like I had said in my previous post, the only thing that I have to modify is the bearings. There needs to be flange bearings on the top and bottom of the bell. I do see what you were saying about the different sized threads, but I guess that I was not explaining myself properly at the fact that I did understand that and that is why I knew that the other gears would fit the NTC3 clutch bell. I'm sorry for not saying that.
I appreciate everyones help tremendously. Once I get everything up and running I'll let you know how it works and if there is any difference.
BB: If this works, you should look into it. It's relatively inexpensive. I think I'll have about $70 wrapped up into this whole project.
Later
Later
#875
Originally Posted by Bundy_Bear
Here are some photos of my Cheese Grator after some dremel work tonight
#876
au: Thanks for all your help. Sorry that I confused you, becuase I was confused as hell myself. I have all your notes, but I guess that I didn't understand them until I actually seen physically what we were talking about. I'm more of a hands on guy. I need to see it and hold it for myself to understand what is being talked about, but at least on here I will get the basic understanding of what I am trying to accomplish.
Yeah yeah yeah, "buy a new front bearing". Thanks for the English correction. You will see that my english skills suck. I got a "D" in Junior English in High School.
BB: When I get around to it, I'll post a pic of my chasis, it looks a hell of a lot worse than yours.
Take care guys, and Thanks a bunch.
#877
BB
#879
New engine
please can some one tell me which engine should i get.... am looking at two rody or jp
#880
Both are great. The Modded JP will be a bit faster probably, but also more expensive. Where are you racing? How big is the track? I'd also take a look at the Tim Hotts N12 Noavrossi motor as it's a great motor. The RB Rody is a lil finicky to tune, but if you get them set right they scream. My Rody, unfortunately the first model, is a bit slower than the ROAR and EFRA version, but a lot more reliable.
#881
RB V12/JP FX 12
#882
V12 Rody ROAR>V12 Rody EFRA
For the price the JP comes with ceramics bearings while the RB doesn't and is probably faster. Regardless they are all fast motors. If your track is a small to medium size neither of these engines are worth spending the $$ on. They are great for those huge tracks with a lot of wide turns, long backstretch, and wide infield. Since they are all modified they will require careful tuning and 8th of a turn makes big differences.
#883
Thanks HarKonnenD
I think i will get the two engines and see which one i like ... here a pic of the track we run on.
#885
Selling a few spares, you guys maybe interested.
Darn - Pretty nice track!!
Q: Why do so many tracks have the straight right under the drivers stand where your field of view is the smallest? I much prefer the straight on other side where you can see more of the track for those high speed runs then the infield closer for those technical areas
