Old 02-07-2005, 11:10 AM   #526
spenzalii's Avatar
Send a message via AIM to spenzalii
Why are you selling? And for how much? Not sure if I'm ready to buy just yet, but I will soon
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 02-07-2005, 11:15 AM   #527
TexasRacer's Avatar
Send a message via AIM to TexasRacer
Give me a call and ill give you all the information you need.
512-922-9654
Thanks!
TexasRacer is offline   Reply With Quote
Old 02-10-2005, 10:11 AM   #528
spenzalii's Avatar
The Ofna boys look like they're holding their own at the Winternats
http://www.winternats.com/2005/2nddayqual.htm
Hope they fare well this weekend!
Old 02-10-2005, 11:10 AM   #529
kevink2's Avatar
Good luck to Jeff and Paul!
kevink2 is offline   Reply With Quote
Old 02-12-2005, 01:32 PM   #530
Angry
Has anyone sorted out the diff problem?
I recently purchased a pro kit and am in the process of putting it together.
I am starting to believe that i may have made a mistake in buying this kit, as I can't seem to get the rear diff to turn smoothly. I find this very annoying.
skink is offline   Reply With Quote
Old 02-12-2005, 09:20 PM   #531
spenzalii's Avatar
As long as the diffs are shimmed properly and they turn without binding, you will be fine. They are noisy and a bit notchy when new, but break in nicely. If you can fins 2x6 mm machined screws, use them instead of the tapping screws that came with the diff.
Old 02-12-2005, 10:14 PM   #532
thanks for the info. i'll try and source the replacement screws.
thanks again.
skink
Old 02-12-2005, 11:17 PM   #533
If its notchy she only needs to bed in. If its locking up you have stuffed up on the shims
And no mistake - the kit rocks!
I think some people bed the diffs in on a drill press, I just did mine in the car <grin>
au_Nightmare is offline   Reply With Quote
Old 02-13-2005, 12:57 AM   #534
Team-RTR's Avatar
you guys are all looking in the wrong direction for the diff screws. back in the days of my LD3 i had serious issues with my diff stripping, then i stumbled across these little babies, Tamiya 2x8 self tapping screws, tamiya part no. 50573. my rear diff was stripped to hell and back and the normal 2x6 screws would not grab inside my diff, letalone 2x6 machine screws. after whacking the 2x8 diff screws in the diff was a rock solid performer for a years worth of hassle free racing. the way the screws are (no pointed end) seems to grab the plastics inside the diff better and be alot more consistent then any other ive tried.
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 02-13-2005, 04:09 PM   #535
spenzalii's Avatar
I actually got the Tamiya 2x8 screws. They were a bit longer than the diff case. I could see the screw start to stretch the diff housing. On one, I believe a bit of fluid started to seep thru! That's why I want to go with the 2x6 machine screws instead.
The 2x8s did work, though, I will say that.
Old 02-13-2005, 08:14 PM   #536
SRAD's Avatar
Default More diff questions...Crystal Park
I'm building my CD3 Pro....what diff oil/grease should I use for the rear. The manual has me using grease(I think) but from looking back in this forum it seems like everyone is using oil in various weights. I run at Crystal Park.....so I'm asking for advice on what to use. I usually run 1/8 so gear diffs are new to me. This is my first go at sedans so I would like to try a setup that will get me around the track without too much difficulty. Any set up information would be greatly appreciated. Thanks
SRAD is offline   Reply With Quote
Old 02-13-2005, 09:01 PM   #537
i'm running 100k mugen
Might be worth looking at the LD3 thread - almost the same car
Old 02-13-2005, 09:07 PM   #538
SRAD's Avatar
Default LD3 thread
I can't seem to find the LD3 thread...any idea?
Old 02-13-2005, 09:20 PM   #539
C Verano's Avatar
Default Re: More diff questions...Crystal Park
For Crystal Park you can run either the OFNA 120,000 or the Mugen 100,000.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 02-13-2005, 11:21 PM   #540
Default Re: LD3 thread
Here ya go,
OFNA LD3 pro
Just ignore anything about the exhaust as that's different.
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 11:37 AM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 09:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 10:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 05:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 02:19 PM
