Camber, caster, toe >
Camber, caster, toe
Camber, caster, toe
Old 04-23-2004, 04:59 AM
Default Camber, caster, toe
Recently I found a site on suspension set-up but unfortunately did not bookmark it, I thought it was here but a search did not help.
Anyone have an address of a site that list's sample set-ups complete with measurements?
AndyB is offline
Old 04-23-2004, 06:19 AM
ziggy12345's Avatar
Go to the Tech help section of my site
www.ashby-ic.com
No examples but everything you need is there
Cheers
ziggy12345 is offline
Old 04-23-2004, 06:27 AM
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Default Re: Camber, caster, toe
you also can go here
and here
hope this helps.
mop
mop_iko is offline
Old 04-23-2004, 09:58 AM
Thanks Ziggy & Mop
AndyB is offline
Old 04-23-2004, 12:56 PM
bballer's Avatar
If those don't help, I would suggest picking up a copy of XXX Main Touring Car tuning guide. It is very imformative
bballer is offline
Old 04-23-2004, 04:09 PM
mckrooz's Avatar
http://www.rctek.com/handling/index.html
mckrooz is offline
Old 04-24-2004, 01:30 AM
mop_iko's Avatar
i have the xxx main setup bible....
but its too technical!!!!
that is why i prefer the link that i have given up there... its kinda simplify things for you.... straight to the point...
but if you need further and deeper explaination on setups... then XXX MAIN SETUP BIBLE... is the best!
go here to purchase the setup bible
if the link doesnt work... go here
mop
mop_iko is offline
