Old 04-20-2004, 05:53 PM   #1
Default Help! Has to fully closed carb gap for idle???
Hi all,
I just bought the Novarossi 5 port engine and borken in with 5 tanks. Engine is running good and keeping it at around 200 degree during break-in period. But i have a question about idle setting. The engine idle fine but when i look at the gap clearence. It is fully closed. This is my second engine and i remember that usually there is around 0.1mm gap for idleing. The engine should flame out if fuly closed because no air in but that is what i have set now to have the engine in good idle. WHY? The engine rev very very high if i set 0.1mm gap. Did i do anything wrong or just let it closed completely when is idle?
US_MATRIX is offline   Reply With Quote
Old 04-20-2004, 08:41 PM   #2
SlobbaTech's Avatar
Your bottom end could be really lean, I don't like to use temperature for actual tuning but in this case is might help you out a little. How hot does the ending idle at? Run it for 5 minutes then just let it sit and idle for at least a minute before taking a reading. For off-road my engines have never idled higher than 200*, usually like 160-185*. For on-road setup they usually idles cooler but can't remember how much. Other than that as long your engine runs good and not irratic or hard to tune I'd say it should be aight for air leaks like carb/case, backplate, header fits and don't have a reason or know where it's getting it's air from b/c I too think that with carb fully closed it should not be able to get air in.
SlobbaTech is offline   Reply With Quote
Old 04-20-2004, 10:42 PM   #3
I forgot to mention that all new Novarossi 5 port engine comes with a plastic insert in the throat. Is anything to do with that???
Old 04-23-2004, 08:14 PM   #4
Rob Hochberg's Avatar
Send a message via AIM to Rob Hochberg
The plastic piece you're referring to is probably a carb restrictor. Is it possible to remove it?
Rob Hochberg is offline   Reply With Quote
Closed... kenshu Kansas/Missouri Racing 3 11-10-2007 02:23 PM
VFW IS CLOSED.... burm Wisconsin & Illinois Racing 17 12-06-2006 01:23 PM
WTB 11L ROTARY CARB FOR .18TZ, HAVE NEW SLIDE CARB TO TRADE? SHAGGS R/C Items: Wanted to Buy 0 12-01-2006 02:34 PM
Closed..... TimPotter Florida Racing 24 11-19-2006 05:17 PM
traxxas e pede for sale or trade, fully hopped up, fully rtr lildave13579 R/C Items: For Sale/Trade 0 08-02-2002 07:26 AM
SEO by vBSEO 3.5.0
